Old 03-26-2016, 02:33 PM   #15
1996 25' Excella
Tillsonburg , Ontario
I simply removed the hold down crews on our '89. But it had lots of clearance for hoses etc. New one came with gobs of foam packing to keep the hoses away from the adjacent plywood.
JCW
JCWDCW is offline   Reply With Quote
Old 03-27-2016, 09:21 AM   #16
Okstreamer
2007 25' Safari FB SE
Yukon , Oklahoma
Pump silencer
Being retired from the plumbing trade for 45 years, I found that the pump on my 2007 airstream Safari was very noisy. I relocated the pump so that it was easier to work on and mounted it on 1/2 inch foam and firmly attached it to the floor. Then I installed stainless steel braided hoses on the inlet and outlet sides of the pump. I also installed a water hammer arrester on the outlet side of the pump. You can purchase these from any plumbing supply house. Use 1/2 inch size. Anywhere the pex piping touched adjacent pipes or cabinet interiors I installed foam pipe insulation around the pipes. Now I am not sure that my pump is even running when I turn it on. This is what worked for me. PS I hate noisy plumbing, can you tell?
okstreamer is offline   Reply With Quote
Old 03-27-2016, 09:28 AM   #17
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Thanks for this.
When you say "stainless steel braided hoses" are you talking about the stuff one would normally see under a sink. That connects the tap set to the water line? Also what is a hammer arrestor?
Sorry for the questions as it will let you know how much I know about plumbing.....lol
Doug
Edit - just did a Google search on Hammer Arrestor and it looks like something I've never seen before, but should not be hard to install as long as I can find one. Thanks
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 03-27-2016, 10:22 AM   #18
Tincampers's Avatar
Sneedville , Tennessee
I'd like to relocate mine. The literature says the fittings are 1/2"-14 NPSM. I've read these are different from NPT. Will I be able to find longer hoses?
Tincampers is offline   Reply With Quote
Old 03-27-2016, 04:19 PM   #19
1998 30' Excella 1000
Livingston , Texas
I think two loops of the braided vinyl hoses do a better job of isolating the vibration. But, they do require a barb fitting, that some might object to. However, mine have not leaked in 16 years.
Siegmann is offline   Reply With Quote
Old 03-27-2016, 06:40 PM   #20
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Noisy water pump I've decided even though it isn't broken I'm gonna fix it
Spent $100 on a Shur Flo Revolution took 10 mins to install.No more cheap noisy knocking pump.Been 3 years and still enjoy the quiet and more water pressure.One of the better upgrades that you can do.
Now I use cheap noisy pump when boon docking to refill fresh water tank,attached a hose to inlet and outlet then installed some alligator clips on wiring.I carry a jump box that powers it when needed.
Old 03-27-2016, 08:34 PM   #21
Okstreamer
Yukon , Oklahoma
My pump was 1/2 in MIP threads on both inlet and outlet. If you buy 12 in long x 3/8 in braided hoses with 1/2 in FIP connectors on both ends and use a small brass Nipple to make the Conection from the pex and the hose connection. These hoses can be purchased at any Lowes or Home Depot plumbing department.
Old 03-27-2016, 08:42 PM   #22
Okstreamer
Yukon , Oklahoma
Originally Posted by Arcticfox View Post
Thanks for this.
Doug
Yes, these stainless steel connectors are used to hook up lavatories and water closets. They come in an assortment of lengths. Most range between 12 - 18 in and are 3/8 in ID. You will most likely need 1/2 in FIP connectors on each end to make the pump to pex connection. This may vary depending on how your plumbing was installed.
Old 03-29-2016, 09:07 PM   #23
Colo.Dave
2015 27' Flying Cloud
2003 25' Safari
Parker , Colorado
Has anyone installed the Flojet VFLO, variable frequency drive pump? VFD's are supposed to pump only according to the flow, rather than start at full speed, then shut off. Its expensive but uses less volt/amps for smaller volumes, and supposed to be very quiet. I'm a believer that you get what you pay for, but cautious of claims, and relying on user experience.
Dingram/Colo is offline   Reply With Quote
Old 03-29-2016, 09:59 PM   #24
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Have Shur-flo Whisper King in both trailers with hose loop on the output side. Both over ten years old and both quiet. Just make sure the output hose is not laying against anything or there may still be noise. The loop is important.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 03-30-2016, 08:24 AM   #25
Arcticfox's Avatar
Central , Canada
Thanks for the info. I will head shopping today.....
Old 03-30-2016, 10:34 AM   #26
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
Flojet VSD pump
Re: #23 - We’ve been using the Flojet VSD pump for about 2 years. We love the VSD pump. The VSD water pump is really quiet – just a whisper at start up and on low demand. Now we can turn the pump on in the middle of the night, flush the toilet, and the pump noise doesn’t wake up anyone in the trailer. I dare say the old pump may have woken up our neighbors it was so loud. Hardest thing with the new pump is that it is so quiet I don’t think about it, and it is hard for me to remember to turn it off for travel, etc.
When I bought the Flojet VSD pump it was $194 from CW. It came with a strainer and a bunch of adapters to use for the install. The strainer is 40 mesh screen same as my old one, but the new one is much larger. My old strainer was in the waterline about 10 inches away from the pump. The new strainer plugs right into the input port on the pump, and that is how I set it up and I just took the old strainer out of the system.
Good luck with your decision!
RAH is offline   Reply With Quote
Old 03-30-2016, 10:43 AM   #27
Durango , Colorado
Originally Posted by bigreddog View Post
If i had only one complaint about these trailers, it would be the noise the water pump makes..., especially at night. I mounted my pump on a 1/4 inch piece of plywood, and glued a 1" thick piece of neoprene below that, and then glued it to the floor, and the pump did get quieter, but the shock distributed to the plumbing is still causing noise. I like the suggestion of braided segments on both sides, and pipe insulation around the individual lines.. That might work. There has GOT to be a solution.
There is!
Buy a new pump. The Shur-flo Revolution is much much quieter. I can still hear it but is more comparable to a light hum rather than the jack hammer sound of the original pump.
RVDreamer is offline   Reply With Quote
Old 03-31-2016, 07:47 AM   #28
Okstreamer
Yukon , Oklahoma
While you are in there
I forgot to mention an additional plumbing trick I added while I had the pump disconnected. On the inlet side of the pump I installed 1/2 in FIP full port diverter ball valve. One side connects to the pipe going to the fresh water. The other side I installed a FIP to hose connector so it allowed me an opening by switching the valve once a year to fill my pipes with antifreeze. This makes it very easy to do that chore by just hooking a small hose to the valve opening put it in a gallon of antifreeze and turn on the pump, open each faucet until you see the color of antifreeze. Usually only takes a gallon of th antifreeze to do my job. Then I close the valve back to its original fresh water position and screw a hose cap on the open end of the diverter valve and I am done. When spring comes just add water to the fresh water tank and pump all the antifreeze out.
Off to another Trip #2..Just local, though THEPILL 2006 - 2010 International 2 03-07-2010 02:43 PM
The club that isn't even a club Frank's Trailer Works Other Clubs 80 02-24-2010 07:04 PM
Another Dilemma...A fun one though.. THEPILL 2006 - 2010 International 9 02-21-2010 07:58 PM
Battery at 45% even though connected to shore power SilverGate Batteries, Univolts, Converters & Inverters 27 04-17-2009 04:35 PM
