Old 12-17-2010, 03:01 PM   #15
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Originally Posted by Castaway View Post
We have taken 2 showers and I have run multiple tanks of water through the systems while looking for the noise. How else do I bleed the lines?
I have been having the same problem with my 08 20ft. There are 2 places to bleed in mine. The drain taps at the back of the unit,and the drain taps under the seat where the hot water tank is. This always solves the problem until I move to another spot. Then I have to tweak one or two of the drain taps for a second or so,and the noise goes away.
gandttimes is offline   Reply With Quote
Fresh water problem, air in the lines ????? polarlyse Fresh Water Systems 7 07-01-2009 07:07 AM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Leaks in fresh water drain lines Patsyj1 Plumbing - Systems & Fixtures 5 04-13-2007 06:55 AM
noisy water lines kooblekidz Airstream Motorhome Forums 1 08-03-2003 01:35 PM
