Old 09-05-2010, 07:11 PM   #1
1971 29' Ambassador
South Weber , Utah
No water pressure past regulator
Put a new hot water tank in and it tested out fine. Disconnected city water supply to put on door and remove drain valve (replaced with plug so door would fit). Now have nearly no pressure past the city water pressure regulator. could it be blocked or stuck? Any way to blow back or release?
fisherjdou is offline   Reply With Quote
Old 09-05-2010, 08:02 PM   #2
There is a screw at the top of the regulator, that permits adjustment, to a point.
Try that before anything else.
There is a check valve after the regulator, that could be blocked, or hung up. However, check valves normally leak instead of blocking, when they malfunction.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-06-2010, 08:07 AM   #3
1971 29' Ambassador
South Weber , Utah
Thanks Andy
Thought of the adjustment screw but wanted to check first.
Old 11-14-2010, 01:08 PM   #4
1971 29' Ambassador
South Weber , Utah
Found the problem. Might be of use to others. It seems we left the cap off the city water connection for a couple of days. Something tried to build a nest inside (Wasps?). When we applied pressurized city water, the nest jammed up against the checkvalve and plugged the pipe. Had to completely disassemble the pipe and checkvalve then clean out blockage then sterilize the parts. All good now.
Old 11-14-2010, 05:04 PM   #5
You can install a small metal screen that's part of the washer, at the city water inlet, just in case you might leave the cap off again.
Andy Rogozinski
Inland RV Center
Corona, CA
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Is the water pressure regulator really necessary? page.crow Water Heaters, Filters & Pumps 17 05-02-2009 03:18 PM
Water pressure regulator IndyAnne Fresh Water Systems 14 04-15-2008 12:26 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
