Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 04-18-2014, 04:06 PM   #1
Peapod
KenSanLan's Avatar
1985 31' Excella
Dade City , Florida
Question No water pressure in galley, plenty in bathroom
Today I flushed out the antifreeze, and filled the freshwater tank. Water is flowing normally in bathroom shower and sink, but only trickles in the kitchen, even with faucet screen removed. I also connected directly to city water with the same result. Pump seems to be working fine.
We had a water-heater bypass installed over the winter at Jackson Center - no other changes that we know of. Any suggestions?
KenSanLan is offline   Reply With Quote
Old 04-18-2014, 04:06 PM   #2
Peapod
KenSanLan's Avatar
1985 31' Excella
Dade City , Florida
I forgot to say - we have a 31' 1985 Excella.
Old 04-18-2014, 04:39 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
If it's plugged on both the hot and cold position and you're sure the screen/aerator is clean, there must be some gunk in the faucet control. You could take a line loose underneath the faucet to see if water flows, or undo the top of the control and clean it out.
Doug and Cheryl
Old 04-18-2014, 05:01 PM   #4
Peapod
KenSanLan's Avatar
1985 31' Excella
Dade City , Florida
That's what I'm going to do. Thanks - will let you know if it works!
Old 04-18-2014, 07:07 PM   #5
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
There are two screens. One where the hose connects to the faucet head, and another at the aerator where the water comes out. I would bet that one of them is plugged.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 04-18-2014, 07:25 PM   #6
Peapod
KenSanLan's Avatar
1985 31' Excella
Dade City , Florida
Thanks, we'll try that too. I checked the aerator, didn't know about the one at the faucet head. Will be back at it tomorrow morning.
Old 04-22-2014, 06:29 PM   #7
Peapod
KenSanLan's Avatar
1985 31' Excella
Dade City , Florida
Problem solved - we think it was air in the line. Turned it on the next morning and it worked fine! However - we then found a leak under the sink - new faucet installed - all is well. Thanks for your help.
Old 04-22-2014, 07:04 PM   #8
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Ahh, at last, a simple plumbing fix. The moderators should put a sticky on this thread, because it will never happen again.
DryFly is offline   Reply With Quote
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 19 07-03-2019 09:19 AM
new, with plenty of questions Bullit Wheels, Hubs & Bearings 1 08-22-2013 11:31 AM
Low Water Pressure Galley and Shower tinman1 Fresh Water Systems 3 06-17-2012 07:04 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
