Old 04-28-2013, 01:19 PM   #29
Ottawa , ON
2D or not 2D: was that the answer?
Sorry, couldn't resist, plus didn't understand your '2D' comment. Can you 'splain it a bit more?
Old 04-28-2013, 01:33 PM   #30
Lexington , Kentucky
2d was the item on the diagram where the water regulator was supposed to be. Someone, somewhere, sometime took it off. This was before I bought it or when I had the pipes replaced in 2009, 4 years ago.
Lexgirl
Lexgirl is offline   Reply With Quote
Old 04-28-2013, 01:39 PM   #31
Ottawa , ON
Ah! Well, thanks for explaining. So now, you can put one back on, right? Maybe it was taken off because the old one was defective?
It's a Good Thing to have: you could do damage to plumbing if you travelled to an area with really high pressure.
ps: the cylindrical thing in the top picture in post 26 looks like a simple filter, from what I can see of it.
Mebbe it's plugged up with stuff..?
Old 04-28-2013, 01:49 PM   #32
Do you know where to buy one?
Old 04-28-2013, 02:09 PM   #33
Splitrock's Avatar
Sioux Falls , South Dakota
When I first got my trailer the water would just run out on the ground at the regulator. The regulator valve was stuck open. I closed it and then there was no water at all. The inlet backflow preventer was acting as a dam for all sorts of debris. I removed the backflow preventer and cleaned the line back to the inlet hose connection and that solved the water supply issue.
My trailer has two separate but connected water systems. One city supply and one 12 volt pump storage tank supply. Both rely on backflow preventers to work. I have separated those two systems with two valves. I posted pictures of how I did that on my blog. The link to the blog is on the left side of this page.
Old 04-28-2013, 11:04 PM   #34
Ottawa , ON
Any Airstream dealer will have one.
Old 04-29-2013, 08:03 AM   #35
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
First Question.
Are you trying to use the pump?
Or City water?
The device in the photo is an inline strainer. You should see water in it if your FW tank is full. The clear plastic part can be unscrewed to clean it.
The strainer is only in play when you are on House Water (using the FW tank and pump).
So lets start with which system you are trying to use. City or Pump.
TG Twinkie is online now   Reply With Quote
Old 04-29-2013, 09:01 AM   #36
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Ouch! - this is getting to be cruel and unusual punishment for you .....
Going back over some of the earlier suggestion can you confirm that:
- all the faucet screens were removed, cleaned and there was no change?
- the onboard water system (i.e. fresh water into the on-board tank and on-board pump turned on) was used and no change?
- there is no leaking under the trailer
A couple of additional questions:
- when did this problem begin? - was it sudden? gradual over time? after doing work on the water system?
- were the fixtures replaced at the same time that the waterlines were replaced?
- although I'm a little confused by the schematic - if I'm reading it right - it does seem to show that there should be a check valve near but separate from the missing regulator - would this be the picture you showed early on?
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 06-29-2013, 12:54 PM   #37
Dear Jay, I am so sorry I have not responded earlier, but there has been a lot of farm work and I am getting ready for my 2nd knee replacement. Plus after working with it for so long, I had to take a break. This has been going on ever since I moved the Airstream to my farm last August. It was parked at my daughter's in Lexington where the last thing I did any thing to the water system was put in antifreeze liquid for the winter which went fine. When it was parked and leveled at the farm, the water came out normal, then it went down to a drizzle in both bathroom and kitchen. Like I said, I found no water pressure gauge or a water back flow stopper. So I purchased these, along with more connections and pipe to make sure I would be able to put everything together. After getting all the leaks at connections stopped, we could see the water flow in through the new pieces, , but now there was NO WATER coming out of ANY faucets!! Went underneath the AS and there was no water coming out from any pipes at all!! Where is my water going??!! I. Have. No. Idea!! It has absolutely made me sick. So I walked away from that system and put in a new converter. Which was a successful project.!i have a week and a half before my surgery, and I am ready to tackle the water system again. I just don't know where to start. Do I go under the AS and take the pipes apart one by one, or start at the kitchen sink and take those pipes apart and snake it to see if it is stopped up somewhere? Any help would be appreciated. New ideas? My brain is stumped! I am a retired school teacher so plumbing is not my forte'.
Thanks for all your help and support. I don't feel alone with help from this site,
Diane
Old 06-29-2013, 01:02 PM   #38
Originally Posted by TG Twinkie View Post
First Question.
Or City water?
I am using city water, not the FW tank. There is a valve past the pump that when you open it the water flows out onto the ground. So I know water is getting to at least this place in the line. Where it goes after this is anyone's guess, but it is not coming out of the faucets. Any ideas?
Lexgirl
Diane
Old 06-29-2013, 01:04 PM   #39
I have that filter out and cleaned it. No change.
Lexgirl
Diane
Old 06-29-2013, 01:09 PM   #40
Ottawa , ON
I wonder if there could be something that somehow got into the water lines and is blocking them?
If you have one of those little adapters with a Schrader valve on one end and a garden hose fitting on the other (they sell for about two bucks), why not try blowing the lines out and see if any of the taps let air out?
If you have a compressor, that is. But what farm doesn't?
Sorry to hear about your knee replacements.
I know I need them but I fear the trials and tribulations of going through the surgery.
Old 06-29-2013, 03:11 PM   #41
Well , I have been putting up a good fight with a little mouse!!😀🐭
Old 09-06-2017, 06:45 PM   #42
To Gulls
To Gulls's Avatar
2007 25' Safari FB SE
Pensacola , Florida
We had a water pressure problem when hooked to city water....it was good pressure at first and then slowed to a stream on all faucets in the trailer....turned out we had black muck in the screen where the hose connects to the trailer....check that out and if dirty, take a tooth pick and clean it, rinse it and then hook the hose up. Worked great after that! We usually rinse the hose prior to hooking it to trailer to avoid this issue. So Simple but true!
To Gulls
Tami & Brenda - Pensacola, FL
2007 25FB Safari Special Edition LS
2008 White Toyota Tundra 5.7L V8
"There is no present like the time."
To Gulls is offline   Reply With Quote
