Old 12-28-2014, 09:58 AM   #15
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
check valve/regulator
I have a similar problem, does anyone know where these are located in a 1973 Tradewind? Thanks!
moparjohn is offline   Reply With Quote
Old 12-28-2014, 10:21 AM   #16
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
In my 73 30' rear bath/center twin, I vaguely remember (it's been more than 25 years ago) the regulator being inside the rear compartment near the floor. There was a big brass plug in the base of the regulator that covered a copper/brass removable screen. That screen would corrode, turn green, and get full of sediment. I'm not sure if it was original or had been added by a previous owner. In those days I was using the trailer at the beach where well water was the norm, also with no inline filter.
Alan
Old 12-29-2014, 04:39 AM   #17
Peapod
KenSanLan's Avatar
1985 31' Excella
Dade City , Florida
No water from city line
My mom went out for a while yesterday morning and when she came back two of her AS neighbors had fixed the problem. It was the valve. A couple of years ago the inlet was replaced because it was leaking. They took the valve from the old one and switched it out for the "new" one. Problem solved. Once again proving that the best thing about Airstreams are the people that own them. Thanks, everyone.
KenSanLan is offline   Reply With Quote
Old 12-29-2014, 04:58 AM   #18
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
The spring loaded check valve at the city water inlet is the first thing that comes to mind. I would think that even if stuck, the pressure of the city water in the hose should
open it - but maybe not!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-29-2014, 07:30 AM   #19
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Originally Posted by KenSanLan View Post
My mom just arrived at her AS in Florida to discover she has a water problem. There is no water coming into the trailer through the city hookup. She filled the freshwater tank and can use the pump to get water in the trailer, but no water from a direct hookup. Any idea what might be wrong?
I know this sounds like a stupid question. Is there water coming out of the trailer park city water?
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 12-29-2014, 07:36 AM   #20
Venice , Florida
Images: 14
Airdreamers
WBCCI #8880
AIR #41310
Old 12-29-2014, 07:43 AM   #21
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
This story sounds strangely familiar. If your mom is at TR, it was discovered that one of those little lizard guys climbed into the trailer hose connection. In this case, when the hose was connected and turned on the little lizard got squashed up against the filter at the high pressure water regulator. I cut the plex pipe, fished the dead guy out and reconnected the water pipes. The solution would be to screw the ends of the water hose together when it's not being used and to screw a plastic plug into the hose connection on the trailer.
NOAZRK2690 is offline   Reply With Quote
Old 12-30-2014, 08:36 AM   #22
Venice , Florida
Images: 14
BTW, nothing to do with the water situation but, Travelers Rest in Dade City is a place you should all visit. Great place great amenities and all around people and Airstream friendly!!
Airdreamers
WBCCI #8880
AIR #41310
Old 12-30-2014, 04:09 PM   #23
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
I had the same problem with my 2001 Safari when it was about 4 or 5 years old. I bought it new in 2001 and still own it. I ended up replacing the water pump (cost about $75) and the problem was solved. I thought it may have been caused by a plugged check valve in the pump. Not sure, but the pump replacement solved the problem and it's been about 10 years with no repeat problems.
Nomad518 is offline   Reply With Quote
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 03:07 PM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Connected to city water...NO WATER! Sovereign86 Fresh Water Systems 7 06-13-2007 12:00 PM
