Old 10-08-2015, 11:10 AM   #1
1993 25' Excella
CLeveland , Ohio
No Water Coming out of Faucets
I have worked off and on for two days to figure this issue out on my 25 ' 1993 Excella. The water pump works but I cannot get the water to flow normally out of the kitchen faucet. The bath faucet seems to push air.
This pic shows a filter that had a crack in it. It is beside the water pump. I ordered a new one, but glued this up so I could run water. I see water sputtering inside the filter. COuld that be the issue or am I missing a valve that sends water to the bath and kitchen faucets?
Note in this pic that the left faucet shoots a steady stream with or without the water pump on.
Not sure if that indicates a problem elsewhere. Thanks in advance.
Akronguy is offline   Reply With Quote
Old 10-08-2015, 11:20 AM   #2
1974 Argosy 20
Kooskia , Idaho
First, the last photo shows the hot water by pass valve open (vertical) and it should be closed (horizontal). It is only to be opened when you are by passing the water heater for winterizing. It is the valve on the vertical pipe between the top and bottom horizontal pipes.
Second, the cracked and repaired strainer (first photo) I am sure is still leaking air, and that will only be solved with a new one.
Third, most likely the strainers in the kitchen faucet are clogged, allowing no water through. Always remove and clean the faucet aerator screens when you have no water flow.
Old 10-08-2015, 12:38 PM   #3
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
What idroba said.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 10-08-2015, 12:46 PM   #4
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Your kitchen aerator is clogged with sediment. Take it off, clean, and/or replace. This is to reinforce what Idroba said. You should clean all aerators every year.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-09-2015, 08:52 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
The cracked filter will allow air into the system and reduce the water flow. Fix that and set the bypass valve, center one, to horizontal.
The valve handles indicate flow or off.
2004 Excursion 4x4
Old 10-09-2015, 06:10 PM   #6
1993 25' Excella
CLeveland , Ohio
Thanks everyone. Waiting for the part to replace the cracked filter. WIll see what happens then.
No air coming through faucets with winterizing/using compressor MStewart Winterizing, Storage, Carports & Covers 21 10-26-2011 09:34 AM
Water Pump Vomits water out of faucets! thoreaulycra Water Heaters, Filters & Pumps 5 12-19-2008 11:12 PM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 10:00 AM
Changing out faucets- what size copper piping? charlie tuna Fresh Water Systems 10 08-22-2006 11:02 AM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 07:06 AM
