Old 06-17-2014, 05:27 PM   #15
Rhino33's Avatar
1980 31' International
Cincinnati , Ohio
We are experiencing the same issue with our 1980 31' CB. Pump runs (rather loudly), no water even though the fresh water tank is over half full. Did find a crack in a T valve under the kitchen counter (in the skinny cabinet - of course.) Now trying to find replacement T valve and praying other connections are solid. (suggestions welcome!) One note - our trailer sat for 10+ years due to the PO's extended illness. They thought they winterized after their last trip, but that was years ago. Could this be a dry diaphram issue?
We'll then try to prime our pump to see if it will work. At least we have easy access to the water pump, so that's a plus.
Rhino33 is offline   Reply With Quote
2008 Safari Sport 17' water pump dlb435 Water Heaters, Filters & Pumps 0 03-02-2014 07:43 AM
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 04:49 AM
Fittings for fresh water tank cosmos Fresh Water Systems 0 06-05-2011 04:27 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 12:00 PM
