06-16-2015, 11:56 AM
1978 23' Safari
Albuquerque
no flow when connected to trailer park water
Hello fellow Airstreamers.
I'm a newbie with a freshwater question. I'm a full-timer who recently returned to my 23' 1978 Safari after a 6-month absence and cannot seem to get good flow after re-connecting my trailer park's supply. When I run the pump I get decent flow, but no pressure if I don't run the pump. I know that the park's water supply is pushing sufficient pressure because I used it to fill my freshwater tank.
Any thoughts or suggestions would be greatly appreciated.
Lunchbox
06-16-2015, 12:01 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
Sediment in the shoreline inlet screen?
Regards,
JD
Jeff & Cindy
06-16-2015, 12:12 PM
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
A valve going wrong way?
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
06-16-2015, 12:51 PM
Princeton
, New Jersey
First place to look is the screen at the input connection. Second test the flow from just the hose itself.
2004 Excursion 4x4
06-16-2015, 02:34 PM
2006 23' Safari SE
I'm In
, Kentucky
My faucet aerator screen was almost totally blocked with sediment from the hot water tank when it filled. I cleaned the screen and all was well.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
06-16-2015, 03:13 PM
1999 34' Excella
Hillsboro
With park water attached, turn on the external faucet...it runs off the water pressure inside the RV. If no 'flow', then the screen on the inbound city water is restricted. There are some possibilities where the 'inlet' pressure regulator may be corroded...or otherwise obstructed..
Peace and Blessings..
Channing
WBCCI# 30676
06-16-2015, 09:42 PM
1978 23' Safari
Albuquerque
thanks
Thanks for all the tips, guys.
Unfortunately, my trailer doesn't have a screen at the fresh water inlet...but that suggestion got me thinking that the blockage might be in that area. I removed the check valve and verified that it worked, so I've narrowed it down to the regulator and/or the horizontal line which feeds it. I'll keep you posted.
06-17-2015, 07:46 AM
Jay
, Oklahoma
Once you get things working, pick up a package of garden hose washers with screens and install one in the fresh water inlet.
You will find them in the washing machine supply hose area of any place that sells washing machines.
Regards,
JD
Jeff & Cindy
06-17-2015, 10:50 AM
1967 30' Sovereign
Leavenworth
, Kansas
The screen in your inlet might be plugged up.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
06-26-2015, 04:58 AM
Just a bit obsessed!!!
1974 27' Overlander
1975 31' Sovereign
1965 26' Overlander
Charlotte
They only way to get mine to work (74 Overlaner) is to fill the tank. Is ther a valve to bypass the tank if hooked to a water source?
07-06-2015, 11:21 PM
1978 23' Safari
Albuquerque
Hey guys, turns out the 37-year old pressure regulator was the culprit. Took it apart and found it all corroded and stuck. A few splashes of vinegar and some elbow grease got the valve moving again.
I'll be sure to get some screens on the inlet side to hopefully keep some of the minerals out of the regulator in the future.
Thanks for everyone's suggestions.
Lunchbox
07-07-2015, 06:29 AM
1999 34' Excella
Hillsboro
Great! Sometimes you just have to "dig in!"
If that part is corroded, have you flushed your water heater?
Channing
WBCCI# 30676
07-08-2015, 12:35 AM
1978 23' Safari
Albuquerque
Great question, cwf. I did, but didn't watch it very closely to see how much gunk may have come out. Probably not a bad idea to flush that thing again, I'm thinking.
07-09-2015, 08:39 PM
1999 34' Excella
Hillsboro
Some folks have run 'white vinegar' through theirs... I have not... I figure a good flush should be sufficient.. You could use a soft wire to see if you can scrape out any larger chunks that might/might not be there..
Channing
WBCCI# 30676
