Old 10-19-2007, 11:21 PM   #1
1974 29' Ambassador
1971 31' Sovereign
Klickitat , Washington
Newbie with a leaking pressure regulator
Just got my 74 29' Ambassador, rear bath, and I'm having old trailer issues, both electrical and plumbing. This is the most immediate plumbing issue.
When the trailer is hooked up to city water, the internal pressure regulator reduces pressure by spraying water all over the rear compartment. My RV park manager says these days most RVs use a pressure regulator on the hose.
Would it be OK to just remove the internal regulator, replace it with straight pipe, and use an external regulator on the hose? Or would it better to go with the original design and replace the internal regulator? Or is there yet another way?
jacqueg is offline   Reply With Quote
Old 12-07-2007, 08:04 PM   #2
1994 30' Excella
2012 25' FB International
Anchorage , Alaska
similar problem to you.
Will watch this to see what comments you come up with. My wife and I just pulled our couch out and noticed that our pressure regulator had been leaking as well. Also, ours was mounted right next to our furnace, even though the instructions clearly state; not to mount near heating source. Ours is still laying on my workbench. Would be nice to just replace with hard tubing and use an outside pressure regulator. Bev and Pat
bpcaudill is offline   Reply With Quote
Old 12-07-2007, 08:35 PM   #3
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
jacqueg, bpcaudill:
You will find some answers and ideas in this thread -
http://www.airforums.com/forums/f445...ons-26471.html
Sergei
SmokelessJoe is offline   Reply With Quote
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water pressure regulator...from factory? Kistler Our Community 6 07-14-2007 09:29 PM
Pressure Regulator Cracker Fresh Water Systems 1 08-07-2004 12:05 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 07:26 PM
