Old 02-25-2015, 07:20 PM   #1
1976 Argosy 26
Dade city , Florida
Newbie to RVing
I cannot get the plumbing system to work either through the pump and tank or city water hook up. The system was winterized when we purchased are 26 foot Argosy.
Djnole79 is offline   Reply With Quote
Old 02-25-2015, 07:26 PM   #2
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Have you closed the water tank drain, put the plug back in the water heater, and un- by passed the water heater?.
terryV is offline   Reply With Quote
Old 02-26-2015, 05:11 AM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welcome Djnole79. I hope you enjoy your vintage Argosy, both traveling and working on it. It seems like there is always some problem to solve. Part of the fun for me.
I think I would start following the path of the city water starting at the connection hose. Look for reasons that would block the city water pressure and flow. There may be a pressure regulator, or a "one way valve", or a shut off valve, or a filter right close to the city water inlet. Any of these components could block city water. Once you know they are all good, then follow the line to the next component. If all three shut off valves at the water heater bypass are closed, it could block city water pressure depending on how the water heater is plumbed in. Most water heaters are fed from the "main" line, so it is likely some cold faucets would work.
A plumbing system is just pipes and valves. Just follow the city water along its pipe and try to figure out what could be blocking it. Once you get the city water pressure and flow working, you can test the fresh water tank and pump.
David
Old 02-26-2015, 05:26 AM   #4
Gainesville , Florida
Will the water pump turn on? Did you fill the tank? Just thoughts. Peace,jim
Newbie to rving nesoutlook Sprinter and B-van Forum 2 09-25-2013 05:31 PM
Newbie at airstream and rving, many questions!! sharley0716 Member Introductions 3 04-04-2013 06:32 AM
New to RVing alkotake Member Introductions 5 09-13-2006 08:56 AM
new to RVing and Airstream macandannie Member Introductions 8 05-25-2006 06:28 PM
Nostalgia, Or How You Began RVing overlander64 Off Topic Forum 5 01-24-2003 11:43 AM
