Old 08-13-2007, 01:47 PM   #1
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Newbie Questions
I apologize in advance for any redundancies.
I recently purchased a 1962 28' Ambassador and have some questions regarding the fresh water system. I have filled the tank with no issues, did not see any leaks etc. Mine fills on the streetside of the coach, there is a flip open door with a gate valve to connect a garden hose.
Here are my questions:
1. I left the garden hose connected in the RV park for pressure, I assume this is the correct procedure?
2. I see a lot of talk about water pumps, I am assuming that is for when you are not connected to a city water source.
3. Where would the water pump be on my coach? The tank is under the rear double bed on the streetside. I would guess that the pump should be in that vacinity.
4. There is a light switch over the sink that does not seem to be connected to anything, could this be for a 12V pump? I have not removed the bed to see if there is a pump there as I am not sure where it should be.
Any words of wisdom on my questions are always appreciated. I have learned a ton from this site, everyone has been great!
Louis Hall
LHall is offline   Reply With Quote
Old 08-13-2007, 03:57 PM   #2
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
Hi there, and welcome! This is a great resource, and hopefully you can find answers to all of your questions here.
I can get a couple of them:
1) Yes, leaving your hose hooked up is fine. You may want to get a pressure regulator to make sure you don't have surges inside the coach. they can be found at all RV stores. you also may want to shut the water off in case of leaks if you will be away from the coach for an extended period of time (you just never know with hoses).
2) Yes, the pump is for when you don't have pressure. It always helps to carry a good spare if you use your pump!
3) The water pump may be close to the tank - possibly under the bed. That's where it is in our motor home, but I can't say for your application for sure. Other folks will know that one.
4) Dunno about this one, sorry! We have a rocker switch in the bathroom, apparently for the water pump, but it seems to do nothing. I will have to look it up in our manual one of these days...
Good luck, and enjoy your great Airstream! We'd love to see pics if you have them!
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 08-13-2007, 04:03 PM   #3
krikles's Avatar
1965 17' Caravel
west hills , California
I don't know the answer to #4 either, but in my Caravel there is a switch in the kitchen by the sink and this is for the pump. In my trailer the pump is located under the side gaucho.
And congrats on the new trailer! I'm a newbie too - lots to learn
krikles is offline   Reply With Quote
Old 08-13-2007, 04:33 PM   #4
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 32
Louis, on our '61 Overlander there is a light switch next to the stove top that is for the water pump. On ours, the water pump(12v) is under the kitchen sink and it pressurizes the tank(our tank is original). Our tank is also under the street side bed & the fill connector is street side. It sounds like the configuration simular.
Rick--Foley RV Center www.airstreamofmississippi.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 08-13-2007, 06:03 PM   #5
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Thanks to everyone who sent answers.... definintely good info. At least a starting point.
Louis & Sergio
Old 08-13-2007, 07:47 PM   #6
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
You bet cha you can find answers here for every question...but there is a cost...feed us pictures
Welcome aboard!
rob n terry
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 08-13-2007, 09:42 PM   #7
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Be sure to use a hose rated for potable water - a garden hose isn't. They sell lovely white ones at walmart and other places rated for drinking water - no nasty chemicals to leach into water.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 08-13-2007, 10:12 PM   #8
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
In my sis-in-law's 67 Ambassador, her pump switch is in the kitchen close to the sink. Im not sure where her pump is at the moment, but will find out tomorrow!
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 04-22-2010, 11:05 AM   #9
Jezzbell76's Avatar
1966 28' Ambassador
Mobile , NewOrleans
Images: 67
um.....i just had sparkage....in my new ambassador
from a lighter in the bathroom?
i guess they thought of er'thing in the 60's
is that what the switch is in the kitchen!!!
yay
i havent had power to her but 2x now
and i havnt even put water in any tanks or connected yet....im scared to death
ok,,,i see where to put holding tank water,on street side
but ...where do i drain it?
im lookin :/
i know this is really dumb,,,but
what am i to expect?
i see where to connect land hose...but then what
Jezzbell76 is offline   Reply With Quote
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Newbie Overlander Towing Questions 63overlander 1960 - 1964 Overlander 17 05-20-2005 10:44 PM
Newbie with Questions autoist Airstream Motorhome Forums 2 12-15-2002 06:55 AM
Airstream/Argosy Floorplans? Questions from a newbie ErichC Airstream Motorhome Forums 12 07-07-2002 10:29 PM
General Engine questions from a newbie ErichC Mechanics Corner - Engines, Transmission & More... 1 07-07-2002 05:23 PM
