Old 07-04-2014, 05:16 PM   #1
2003 31' Land Yacht 30
amelia island , Florida
newbie needs help with water pump
Know NOTHING about them, put fresh water in tank, turned on and nothing. Can hear/feel pump ? Under bed is pump and 3 water lines, do not know where they go, what they do or when/if to shut off. Can someone help me? Thanks
snickers is offline   Reply With Quote
Old 07-04-2014, 05:57 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
One line from the pump is connected to the FW holding tank, it is the supply to the pump. One line is the discharge from the pump. It could be 2 lines depending on the location of the pump and the trailer layout. The 3rd line could be the city water. Again depending on the layout.
You could have a leak in the supply line or a plugged strainer. Which means the pump can not prime itself. After checking for leaks and perhaps replacing the hoses on the input and discharge side of the strainer.
If you can remove the line from the discharge of the pump. Then run the pump and see if water comes out. If so reconnect the line, open all faucets and start the pump. Then close the faucets, one at a time. The pump should eventually stop as the pressure builds.
Good Luck
Newbie needs help with water heater Pat Cassity Water Heaters, Filters & Pumps 22 09-23-2014 11:02 AM
Newbie Needs Help for Water System Pump weaver1950 Fresh Water Systems 2 08-13-2013 05:20 PM
'74 Ambassador Needs Water Pump Erik Olson 1974 - 1979 Ambassador 6 04-17-2013 08:26 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
