09-18-2016, 12:44 PM
2015 28' Flying Cloud
Newtown
, Pennsylvania
New water pump. YES!!!
Replaced the Airstream "quality" water pump with a Flojet VFlo 5.0. What a difference. Quiet. A whisper at normal flow rates. Flushes the toilet bowl clean with plenty of flow. Wasted so much water to get the old pump to rinse the bowl. Did I say quiet? No off and on hammering. What a joy.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
400ah LiFePo4, 800 watts solar, 2x eu2000i Propane
PD9160 converter, Prosine 1800 inverter
2x Victron 100/30 Smart Solar, Victron Smart Shunt
09-18-2016, 01:33 PM
Biloxi
, Mississippi
I replaced mine a couple of weeks ago with a SHURflo 4008-101-E65 3.0 Revolution Water Pump.
Very easy project with immediate benefits. New pump when running has a hum that I can only hear if I open the compartment door and stick my head in. No more banging and clanging or leaks. Pressure is higher and consistent based on demand.
MICHAEL
09-18-2016, 01:55 PM
2008 25' Classic
Full Time
That is one of the more expensive pumps, $280 to $315. Some reviews in 2013 on Amazon state when the battery charger boosts to 15 volts for bulk charge the pump's intelligence doesn't allow the pump to function. My charger only goes to 14.2v. Have you observed any issues with the pump when charger is in bulk mode? Others state if the battery charge goes below 12.5v the pump does run at full capacity.
Is yours model 42755-0092?
Kelvin
09-18-2016, 02:48 PM
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Bruce
Did you do the change yourself? Any pictures and pricing/ordering info you can share?
09-18-2016, 06:52 PM
Newtown
, Pennsylvania
Kelvin
Got mine at Camping World. Model R4426143A $199.99. My converter boosts to 14.4 volts. I will try running the pump at below 12.5 volts and see what happens. Thanks for the "Heads Up". Now I'm not so happy.
Bruce
09-19-2016, 07:34 AM
Biloxi
, Mississippi
Bruce
Just reading a negative post here is no reason to not be happy if you are satisfied with the performance of your pump.
MICHAEL
09-19-2016, 09:01 AM
2008 25' Classic
Full Time
I would like to upgrade my older Flojet. Compared to the OP results on noise it sounds like a good replacement since it uses the same quick disconnect fittings. Should be drop in replacement which is needed since my pump is in a horrendous location.
Kelvin
11-05-2016, 08:02 AM
2017 25' Flying Cloud
Florence
, Alabama
Kelvin
Did you swap out your pump, yet?
DBLee and Southern Belle on the road
The Colonel and Southern Belle
11-05-2016, 08:04 AM
Florence
, Alabama
Chief, how's your pump doing? I'm wanting to swap mine
11-05-2016, 08:40 AM
2013 28' Flying Cloud
Central
, Canada
Tagging in, as I would like to look at changing my pump out also. Not sure the best one to get (where to get it) or what's involved in doing it. So any input on this would be great.
Trying to use my camera to create memories - not photographs!
11-05-2016, 09:42 AM
1988 34' Limited
Folly Beach
, South Carolina
My original Shurflo 205-213 failed. Took me a minute to find it under the closet floor. I've ordered the 4008-101-E65 from Amazon for $65. It has great reviews, but I will report back once received and installed.
11-06-2016, 06:02 AM
Biloxi
, Mississippi
On my last trip it starting developing a loud pulsing noise and pressure seems to be down a bit. When I have the time I will pull the hoses and recheck for leaks etc.
MICHAEL
11-07-2016, 10:58 AM
1988 34' Limited
Folly Beach
, South Carolina
