Old 06-29-2005, 03:55 PM   #1
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
New Plumbing Installed
We got the new plumbing installed. It isn’t complete but done enough to get our rig road ready by August. We still need to install city water connection but for now we will not need that where we will be going . PEX is easy enough to make changes later without worry.
You can see what we did HERE.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 06-29-2005, 04:04 PM   #2
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I just looked at your pics of the water heater plumbing.
I would recommend a water heater bypass for purposes of winterization and to isolate the water heater in the event of a tank problem with the water heater. I was sure glad mine had the bypass when the water heater tank ruptured on mine. Also, it makes winterization a snap with the pink stuff.
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 06-29-2005, 04:20 PM   #3
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
Water Heater Bypass
There was not enough room with the valves that I had to do that. So the bypass right now is a short piece of tube that will bridge the gap. It's manual but it will work.
1/2 inck PEX is big stuff and the valves are also big. and take up lots of room along with the "T"s, etc. There just was not a pretty way of doing it that I could see...
Old 06-29-2005, 10:29 PM   #4
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
The bypass doesn't have to be right at the back of the water heater. Anyplace back from there before you get to a split off for something else will work to co-join with the bypass the hot and cold lines.
Actually, I would rather have the bypass than the cutoff valves because the bypass does cutoff the water to the water heater.
All a matter of personal preference I suppose....
David
TAC # TX-18
AIR # 410
Old 06-29-2005, 10:50 PM   #5
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
my bypass....
David
TAC # TX-18
AIR # 410
Plastic Plumbing 83Excella Fresh Water Systems 6 05-04-2006 01:16 AM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
'63 Safari Plumbing Schematic? petefundis Plumbing - Systems & Fixtures 1 09-18-2002 06:56 PM
Replacing plumbing lines GTracer Fresh Water Systems 1 06-29-2002 11:02 PM
getting to plumbing maznblu Fresh Water Systems 4 06-05-2002 07:21 PM
