Old 05-01-2014, 08:23 PM   #1
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
New Leak Under Trailer '94 Excella 34'
My 94 Excella 34 sprung a leak when I turned on the water this Spring. Water is dripping from both ends of the square metal box which is located underneath the trailer between the center and rear axles. Both ends of the box have an access panel that is blocked by a heavy foam strip. I can't tell what is in the box but I'm guessing it has the fresh water tank and the plumbing that crosses over. Both water system drains and the tank drain come out of the box. I didn't fill the fresh water tank, so I don't think the water tank broke and I don't have any apparent leaks visible on the inside. Does anyone have any idea what this might be? Could use the help.
Regards,
Don Hetzler
P.S. Does anyone have a drawing of the '94 34' Dinette Excella? Could sure use a copy. DH
Emh142 is offline   Reply With Quote
Old 05-07-2014, 10:26 AM   #2
BIG BOW
1987 32' Excella
1999 35' Cutter Diesel Bus w/slide
Clover , South Carolina
I have the exact same problem in my 1989 32 ft Excella. Have you found out any possible solutions? I eliminated all internal lines and examined area where drain valves are located. Water leak is constant drip from both ends of tank cover.
Gened is offline   Reply With Quote
Old 05-08-2014, 07:21 AM   #3
911Patriot's Avatar
1991 29' Excella
Marco Island , Florida
Images: 42
We had the same problem yesterday. I read up on it and think it may be that the low point valves that were opened for winterizing may still be open. See #7 in this post for a picture of where the valves are located. In my 91 Excella they are below the microwave in the floor cabinet. http://www.airforums.com/forums/f458...html#post56555
Since I came across this potential solution late last night I haven't tried it yet. Hope it works for all of us that probably had someone else winterize our trailers and didn't know of the valves.
911Patriot is offline   Reply With Quote
Old 05-08-2014, 08:08 AM   #4
BIG BOW
1987 32' Excella
Thanks for the suggestion, but my drain valves are not open.
Old 05-08-2014, 08:53 AM   #5
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
On our 1998 Excella, we had a drip and it was caused by the adapter that goes between the tanks and the valves has gotten old and brittle, it's made out of a white plastic, which has just aged. The replacements you buy now are made of ABS like the rest of the plumbing. If you can see a white piece of plastic between the valve and the tanks, you should be able to see the cracked plastic too.
This is the bad part.
Waste tank slip-in adaptor 0310107 [0310107] - $6.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
In addition to this part, you might also need a new o-ring, which is in the valve rebuild kit.
1 Repair Kit 83-8171 [09872] - $21.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Damon
#4827
damonbeals is offline   Reply With Quote
Old 05-09-2014, 08:08 PM   #6
PopHetzler
Emh142's Avatar
Troy , Ohio
I gave up. Took to dealer for repair. I worked back through the fresh water tank to isolate the leak in the hot water side. Possibly an accidental nail from a bathroom flooring re-do. DH
Old 05-09-2014, 08:44 PM   #7
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Tell the dealer that you'd like to find out what caused the leak. Perhaps, you could ask them to take a couple of digital pictures and post them on this thread and then, we all be wiser!
Steve
Steve Bryant is offline   Reply With Quote
Old 05-09-2014, 09:26 PM   #8
PopHetzler
Emh142's Avatar
Troy , Ohio
If I'm no there when they discover the problem, they will take pictures for me. DH
Old 06-12-2014, 04:55 PM   #9
PopHetzler
Emh142's Avatar
Troy , Ohio
Flooring guys shot my hot water line under the floor , full of staples.
Old 06-13-2014, 08:06 AM   #10
1991 34' Limited
Wichita , Kansas
I'd want to make sure that there are no more staples projecting out near the water lines.
Sent from my SM-N900V using Airstream Forums mobile app
Steve
Old 06-13-2014, 08:49 AM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Wow ... sorry that happened! Any pics of repairs?
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-14-2014, 09:49 AM   #12
911Patriot's Avatar
1991 29' Excella
Images: 42
And I found our source to be a loose fitting on a water pipe near the water pump under the closet floor hatch (if that makes any sense.)
Old 06-14-2014, 03:20 PM   #13
1974 27' Overlander
Sammamish , Washington
I mis-measured and drilled a 3/16" hole in the bottom of a potable water tank.
Does anyone know if there is a way of patching the hole (similar to a car tire) from the exterior without removing the tank?
If not, is there a better place on the forum to post this question where it would bet more exposure?
Chuck Neir is offline   Reply With Quote
Old 06-14-2014, 03:30 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Chuck, get a larger stainless steel screw and run it in the hole.
Channing
WBCCI# 30676
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 03:32 PM
Leak tested under pressure! deauxrite Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 11-23-2009 07:14 AM
Under tub leak Vic Terry Plumbing - Systems & Fixtures 5 08-30-2006 11:11 PM
Leak Under City Water Connection JDL Fresh Water Systems 8 08-14-2006 02:16 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 07:59 PM
