Old 10-19-2011, 04:03 PM   #1
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
New holding tanks & monitor Sys
Hi everybody.
In our 1972 Sovereign there is no holding tanks for the rear bathroom and I'm still struggling with removing the fresh water tank for a water leak test.
What should be the direction to take to install a grey/black water tanks on the rear and also set up a monitor system?
The financial resources are limited for the project so please have that under consideration.
Thanks again.
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 10-19-2011, 04:53 PM   #2
Originally Posted by VeggieBullet View Post
Hi everybody.
Thanks again.
The original black water tank is still available.
However, if your going to add a gray water tank, then your design will have to start from the begining, or use a black and gray tank from later years, but you will have to do some modification at the rear of the trailer.
Old 10-25-2011, 02:53 PM   #3
1973 31' Sovereign
2007 20' Safari SE
location
Hello Andy.
We are totally ready and open to suggestions. We found an original Black Water tank but now the question is: Grey water tank? where do we fit it?
and how do we install a monitor system? in theory it should be easier with the tanks out?
Any idea? inputs or suggestions are more thank welcome.
2 chronicles 7:14
Old 10-27-2011, 07:50 PM   #4
1973 29' Ambassador
Troutville , Virginia
Gray water tank
I added a 45 gal grey water tank to my 73 29ft Ambassador - had a local
company construct a single tank that would fit between the frame cross members directly behind the axles (single tank with a flow between i.e. one tank between one cross member and one tank between another corss member) - I then plumed the sinks and shower to this tank and used the black water vent as the vent for the grey water tank - I also built a separate drain for the the grey water tank. The tank is supported by angle iron supported by a 1 inch piece a plywood (similar to the construction support for the freshwaer tank in front of the axles)
Jim J
Jim Johnson is offline   Reply With Quote
Replacement Holding Tanks 78 Ambassador bw4him Waste Systems, Tanks & Totes 2 08-08-2016 06:37 PM
Dropping Holding Tanks Pans on 31 ft center Bath Excella II perryg114 Belly Pans & Banana Wraps 11 11-07-2011 12:09 PM
Why heat to holding tanks? Breadbug Furnaces, Heaters, Fireplaces & Air Conditioning 12 01-22-2011 10:54 AM
