Old 07-09-2010, 08:30 PM   #1
airdoxy's Avatar
1958 22' Caravanner
gregory , Michigan
New Fresh Water Tank Installation
OK, I've waited months for my new tank to come to replace my aluminum cylinder tank in my 58 Caravaneer and now I need help. It came from Inca or Aztec ( can't remember ) with no holes in it, so I could locate the points of entry. How do I attach my plumbing to the tank? I have a 2" fill pipe coming into the front of it and will need a 1/2" feed line to the pump and drain and probably a 1/2" overflow. Are there PEX fittings for the 1/2" attachments to this type of plastic tank? The metal fill pipe is threaded. can I use ABS pipe with this plastic tank? Are the fittings mechanical or glued?
Help!!!!! Airdoxy
airdoxy is offline   Reply With Quote
water tank
Gray Water Tank Retrofit Installation FLYNCLD Waste Systems, Tanks & Totes 8 09-17-2012 08:59 PM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
