Old 06-27-2002, 10:24 PM   #1
New City Water Connection
I just picked up one of the exterior surface mounted city water connectors that Airstream has used off and on for many years. It is plastic, "chrome" plated, and more or less square in shape.
It is more than simple hose connection, however. It has some sort of restriction device built in. I assume it is a backflow preventer. Could it also be a pressure regulator? Anyone actually know?
Mark
Old 06-27-2002, 10:53 PM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
City water connector
All city water connectors have backflow preventers. Once in a while the springs get cocked and you will lose water if the cap is not screwed on tight.
Yours may or may not have a pressure regulator. I was just in Camping World today and the ones I saw with regulators were a couple of dollars more expensive, but didn't look any different from the unregulated ones.
Best to put a regulator at the RV park faucet anyway. That protects your hose as well as the trailer. I had a heck of a time teaching my wife that the regulator stayed with the hose, not with the faucet.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 06-28-2002, 06:05 PM   #3
When I say I picked up the version used by Airstream, I meant that litterally. I got it off a fairly late model Excello at a RV salvage.
I also have the original in-line pressure regulator, so there is no harm one way or another, I was just curious, mainly.
Thanks for the help.
Mark
Old 06-29-2002, 05:01 AM   #4
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Lightbulb city water connection
Was this connector on the outside of the A/S? If so, it may well be nothing more than, just a wire strainer to filter trash from getting into your trailer water line. As most pressure regulators that A/S installed were in fact closer to the actual water pump itself.
Just a thought.
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-01-2002, 07:57 AM   #5
Further investigation has determined that the device contains a backflow preventer only. It is made by Sureflo, and mounts on the exterior of the body.
Thanks for the suggestions.
Mark
Old 07-01-2002, 08:03 AM   #6
1984 29' Sovereign
Savannah , Missouri
CITY WATER
Just to say, I use a backflow regualtor outside as well...figure twice wouldn't hurt..Mine is one of the brass connector type..seemd to work..so far, no problems with water...
WBCCI 5292 AIR 807
NEU #64
New England Unit
City Water Regulator odfarley Fresh Water Systems 2 08-26-2003 11:28 AM
City Water Valve Assmbly Question sladew Fresh Water Systems 3 08-11-2003 11:38 PM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 01:48 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 05:43 PM
City water 53flyingcloud Fresh Water Systems 2 07-11-2002 01:08 AM
