Old 06-21-2012, 04:09 PM   #1
L911's Avatar
1971 18' Caravel
Cookeville , Tennessee
Images: 12
Neoprene tubing
I had a couple burst copper lines (from the previous owner) anyway I "repaired" the sections with clear braided neoprene tubing & stainless clamps. The tubing comes in various sizes & fits right over the copper lines.
Has anyone tried this before, it seems to me it would work about as well as PEX & i can keep the original copper valves. According to the web site its FDA approved.
Heres a link to the hose, although i bought mine at Lowes.
PVC Braid Reinforced Hose Tubing
L911 is offline   Reply With Quote
Old 06-21-2012, 04:54 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have used it in the past and am using some in the trailer we usually travel with. The only problem I have encountered is the hose clamps seem to migrate into the tubing over time and need to be tightened every couple years. It is viable for repairs or a short line, probably a bit pricey to do a whole trailer.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-22-2012, 04:02 AM   #3
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I keep some in the junk drawer with some hose clamps for emergency repairs. All hose clamps should be checked periodically. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 06-22-2012, 06:11 AM   #4
1981 31' Excella II
New Market , Alabama
I believe that tubing goes by the name of Tygon. It will work but like others have said you need to check the clamps often because they will leak. Also Tygon tends to leach chemicals into the water. You know, that plastic water hose taste. Not sure how good that is for you.
Perry
Old 06-27-2012, 11:01 PM   #5
L911's Avatar
1971 18' Caravel
Images: 12
Thanks! I got the idea for using it from the way Airstream had connected the factory water pump.....they used Goodyear Heater Hose. LOL
