Old 02-13-2014, 12:57 PM   #1
Darlington , South Carolina
Need to repair water line, suggestions?
jrussjr is offline   Reply With Quote
Old 02-13-2014, 01:36 PM   #2
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Looks to me that the metal pipe fitting could be separated and it is a union connection. The plastic pipe could be cut and a coupling added with a pipe and female pipe thread piece added to duplicate what is there now. Shouldn't be to bad of a fix.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 02-13-2014, 01:47 PM   #3
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I can't tell if the piping above the fitting is cpvc or copper.
I don't like cpvc especially in a trailer because it does not take the vibrations and movement very well. I would remove the cpvc and install Pex where it is easy to do so.
Dan
Old 02-13-2014, 02:31 PM   #4
Dan, I have heard a few negatives concerning Pex, I take it you haven't had much problems with it? I'm new to trailering so I definitely fit the bill as a "green horn", so any advice is welcomed!
Old 02-13-2014, 02:40 PM   #5
I bought a 1/2" coupler device that I could simply slip over the copper on one end and the CPVC at the other end then tighten both ends as there are rubber "grommets" in each end. However, I ran into two problems: 1. I was told this was 1/2" (it looks to be 3/8") and 2. I was told that there was no fittings where the break was located.
Old 02-14-2014, 09:08 PM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
I am a home inspector and am not aware of any negative comments about Pex. It is the best material for a trailer IMHO.
1/2" piping has 1/2 id and 5/8 od.
Take some good photos of the problem area and take to the plumbing shop.
Dan
Old 02-14-2014, 09:42 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I was skeptical, but after investigating and running all pex in my trailer I am sold on it.
Easy to instal and robust.
I am about sure that if I had used PVC in my build, it probably would not have fared so well last week in very cold west Texas.
As for the op's dilemma with the coupling, the problem with is inside diameter measurement v . Outside diameter measurement, but you might be lucky enough that the coupler might seal.
Water heater tank hole repair at fitting: weld? rippie Water Heaters, Filters & Pumps 5 01-29-2014 04:02 PM
Pressurized Water Line Drain Petcocks Phil&Sher Fresh Water Systems 24 01-27-2014 01:06 PM
Gray Water Tank Flush Road Geezer Waste Systems, Tanks & Totes 6 02-01-2012 06:23 PM
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 04:49 AM
Split water supply line Eliminator46 Fresh Water Systems 10 05-03-2011 06:43 AM
