Old 04-07-2010, 07:50 AM   #1
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
Need to clean fresh water tank?
How do I clean my fresh water tank? I get some fine black sediment from time to time coming through the fixtures.
tcrum is offline   Reply With Quote
Old 04-07-2010, 08:16 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Occasional "fine black sediment" sounds like the rubber hoses are deteriorating - any sediment in the tank usually stays in the tank.
To truly clean the FW tank its a drop the tank chore.
Old 04-07-2010, 08:28 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Black stuff is coming from the pump. If you over sanitize your tank and lines, the "Clorine" in bleach will start eating rubber. 1 gallon per thousand to sanitize. 1/10 that to kill the critters in the water.
Michelle TAC MT-0
Sarah, Snowball
Old 04-07-2010, 08:41 AM   #4
tcrum's Avatar
1978 31' Sovereign
Thanks for the great advice.
Old 04-07-2010, 09:25 AM   #5
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
http://service.airstream.com/files/l...0575ffe706.pdf
Birdwell57 is offline   Reply With Quote
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Fresh water hose - keep it clean? Sierrapapa Fresh Water Systems 15 07-20-2007 05:04 PM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
Regarding original water tank clean out - thank you! 60stradewind Fresh Water Systems 0 08-22-2002 12:00 AM
