Old 03-20-2014, 05:39 PM   #1
Airline's Avatar
1972 29' Ambassador
grants pass , Oregon
Need fresh water line help '72 29'
Hi Airstream Lovers !
I am fixing some split copper fresh water pipes by replacing with pex.I am about to hook up the hot cold lines witch I think are going into the hot water heater.I am not sure witch line is Hot and Cold ( I did not mark them)
Can anyone tell me which of these two lines (with the new sharkbite fittings) is hot and which is cold ?
This is on a 1972 Ambassador 29' rear bathroom.
thanks !
ID:	207932   Click image for larger version
1972 Ambassador Itn'l 29'.Custom Interior
1987 Avion 34X
1985 Avion 30R
Airline is offline   Reply With Quote
Pressurized Water Line Drain Petcocks Phil&Sher Fresh Water Systems 24 01-27-2014 01:06 PM
Fresh Water Tank Questions CeloNC Plumbing - Systems & Fixtures 0 01-10-2012 03:35 PM
Outside fresh water door lock won't open willbrackman Exterior Storage Compartments & Access Doors 12 11-02-2011 12:27 AM
Fresh Water Pump moosetags Fresh Water Systems 5 05-31-2011 07:08 AM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 10:46 PM
