Old 02-16-2011, 01:01 PM   #1
Denbear's Avatar
1975 27' Overlander
Eugene , Oregon
Need advice on '75 Overlander w/ frozen/burst water lines
Was away for the weekend & freeezing temps burst the fresh water pipe. Not in accessible area under kitchen sink, but somewhere along the way. Is this a reasonable DIY job? Any guesstimate of dealer repair $$$?
Denbear is offline   Reply With Quote
Old 02-16-2011, 01:12 PM   #2
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
Depends where it is. I had two splits under the bed and one at the right rear corner that I could access from the rear hatch (just). I had to take the bed apart to get at the ones under it though. Time consuming but not hard. Cut out the split sections and double clamped reinforced hose on the pipes. Will do until I replace the whole shebang some day. So first find the leak(s)...............Phil.
pgr32e is offline   Reply With Quote
Old 02-16-2011, 03:28 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
Mine had copper in it that was not leaking, but had been frozen at some point(s). I have removed it all except the regulator and the crossover. Camper trailer plumbing is a DIY job for me. I plan to replace mine with PEX.
Old 03-01-2011, 08:47 PM   #4
1972 Travelux Princess 25
Cobourg , Ontario
Couple of tips. Use PEX don't try to fix old copper pipe. And, pressurise the system with AIR not water for testing purposes. Use a spray bottle with a little dish soap added, spray on any suspect joints and you will see plenty of bubbles if there is a leak.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Water Hose - Hard Water Deposits Al - K4GLU Fresh Water Systems 4 02-16-2011 04:00 PM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 12:00 PM
Cleaning up charcoal water! yve79 Winter Living 2 02-07-2011 10:13 AM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
