Old 03-01-2011, 06:29 AM   #1
Lothlorian's Avatar
Loganville , Georgia
Need a second opinion on 51yr old tank
I think I read that the metal freshwater tanks that are from the 50's and early 60's are not good to use. Crud and break down inside. Is that true. I could see white crud on the inside walls.
I was thinking of filling it with water and cleaning the inside and reusing it. Opinions please
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 03-01-2011, 08:55 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
You can remove the lime with an acid cleaner but that does pose some risk of creating leaks.
The problem with older tanks is that they may develop leaks at any time and since they are difficult to remove it is often thought to be wise to replace them even if they are not currently leaking.
Old 03-01-2011, 10:11 AM   #3
Lothlorian's Avatar
Thanks that is what I was thinking. You just sold me on replacement of that tank. I have one gray that will fit, but I am going to put in a second under one of the twins. I want atleast 42 gallons of fresh water.
Brian
Brian & Adrienne
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 06:50 AM
New Slant on Tank Sensor Cleaning... Mexray Waste Systems, Tanks & Totes 5 01-30-2011 01:07 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
