Old 10-25-2010, 01:02 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Need a pop-off valve
Does anyone know where I can get a "pop-off valve" to install in the water line? Mine was never there and I put in new pex tubing and assume I need to install one.
adwriter73 is offline   Reply With Quote
Old 10-25-2010, 01:25 PM   #2
1976 Argosy 28
Cleveland , Georgia
Most hardware stores should be able to help you. The pop-off valve is the same as used in your home. Mr D
Mr D is offline   Reply With Quote
Old 10-25-2010, 01:49 PM   #3
The high pressure pop off valve used by Airstream is part #16522.
I Have never seen that valve used anywhere except in an Airstream.
Old 10-25-2010, 02:37 PM   #4
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
I tried several stores. No one seems to have a clue what I'm talking about. Does it have another term? Where is is used in the home? The water heater?
Old 10-25-2010, 07:53 PM   #5
Kevin245's Avatar
I don't know that they are RV specific but you can try searching "Pressure Relief Valve".
WW Grainger has them.
http://www.grainger.com/Grainger/ecatalog/N-/Ntt-pressure+relief+valve?Ns=List+Price|0&sort=DD
McMaster-Carr has them listed as Pop-Safety Valves on catalog pages 467 - 469.
McMaster-Carr
They come in "Vented Outlet" or "Threaded Outlet" styles. The latter will allow you to plumb a drain line outside your living space should an over pressurization occur.
You might also try a local plumbing supply house?
Kevin
Eleanor Roosevelt
Old 10-25-2010, 08:32 PM   #6
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Is the purpose of it just to protect the interior lines from over-pressurization from a city water hookup? I removed the one from my trailer because I bypassed it when I removed the city water hookup.
Stephanie
Old 10-25-2010, 11:38 PM   #7
Maniacal Engineer
barts's Avatar
Menlo Park , California
I'm guessing here, but I think the reason these were installed was to protect the 12V pressure pump and perhaps the shower hose from too high a city water pressure in case the regulator failed or got stuck. The copper lines would easily handle full city water pressure or higher - I've routinely put 200 psi through similar copper lines on our steam launch. The water heater also appears plenty robust enough to handle 100 psi or more.
In any case, limiting the water pressure to 40 psi or so is a good idea, and such valves are readily available as others have noted.
One thing that would be an improvement in the water handling on Airstreams are fine screen filters protecting the pump intake and the city water inlet. Debris in the water line (rust flakes, etc) will raise hob w/ check valves, water regulators and the like; such simple filter really make pumps, etc. more reliable when the water gets "chunky".
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 10-27-2010, 10:02 AM   #8
1976 Argosy 28
Cleveland , Georgia
I think I need to clarify what I said about the pop-off or pressure relief valve. I didn't mean they all had the same maker or serial number, only that they all serve the same purpose. They are common fixtures in water systems everywhere from the largest buildings to the camper trailers. They are to protect your complete water system. Even though copper lines may bear pressures of 200 lbs. or more the faucets, commodes, shower valves, water heater, and supply lines, etc. will not. If you go to a hardware store and ask for almost anything for a "trailer" they will tell you they don't have it. If you don't mention trailer and tell them specifically what you want, ie: a 4 inch or 8 inch faucet or a commode supply line etc., they will have it almost 100% of the time. I did warranty work for several mobile home manufacturers covering the East coast almost 20 years plus local repairs another few years until I became disabled with CHF and COPD. I hope this helps. Mr D
Old 04-09-2011, 10:12 AM   #9
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Reviving this thread...
I have found adjustable pressure relief valves for $40 - $60, and Home Depot has one you can special order for $17, but it is set at 75 psi. Thoughts?
Old 04-09-2011, 10:22 AM   #10
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
A local plumbing supply house will have one. The big box stores carry what sells quickly.
Michelle TAC MT-0
Sarah, Snowball
Blackwater valve replacement.. tvadman1963 Waste Systems, Tanks & Totes 6 06-14-2011 01:27 PM
Hot Water from Cold Valve txhippiefish Fresh Water Systems 26 04-03-2011 11:05 AM
Removing shower valve in 74 Argosy 24' twilder Sinks, Showers & Toilets 2 04-02-2011 08:28 PM
Check Valve Replacement 73 Tradewind constructor Fresh Water Systems 1 03-20-2011 01:02 PM
1981 Excella II shower valve noreen&sal Sinks, Showers & Toilets 2 03-06-2011 08:06 AM
