Old 06-29-2011, 03:29 PM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Need a 24V fresh water pump
Any advice on the best quality pump ?
Darkspeed is offline   Reply With Quote
Old 06-29-2011, 03:39 PM   #2
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Jamestowndistributors.com is a good place and have a Jabsco max vsd pump on sale. I just ordered one for a customer. I have used several of them on boats (mostly european make boats - hince 24 volt.) and was always satisfied. It is 3.7 gpm which should be sufficient. They don't come cheap but quality usually doesn't.
mhilley is offline   Reply With Quote
Old 06-29-2011, 04:05 PM   #3
Jabsco, 12 volt DC pumps are still great.
Old 06-29-2011, 04:33 PM   #4
Darkspeed's Avatar
1972 31' Sovereign
Thank you! Are they quiet?
Old 06-29-2011, 07:02 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
They all wake up the dinosaurs. It's part of the charm.
Old 06-29-2011, 07:05 PM   #6
mhilley's Avatar
2000 23' Safari
Some noise - not much. Always use accumulator tank. Bigger the better. Brand Andy suggested are usually pretty good too. Check the gpm specs before buying.
Old 06-29-2011, 08:17 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Wrong voltage
Unless your AS has been modified. You have a 12 volt DC system, therefore you need a 12 volt pump; not 24 volt.
Old 06-29-2011, 10:08 PM   #8
Darkspeed's Avatar
1972 31' Sovereign
Going with mostly 24v systems on the rebuild
Old 06-29-2011, 10:18 PM   #9
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Why?
Bill
Just my personal opinion
Old 06-29-2011, 10:35 PM   #10
Darkspeed's Avatar
1972 31' Sovereign
Battery bank is 24v , so for any device that is not a super light load it is easier and more efficient to go 24vdc.
I also have a lot of 24vdc components from other projects (PLC,LED,etc..) that I can re-purpose into the trailer.
I will have a DC-DC converter for the 12v loads but I want to try and limit them to as small as possible.
Looking at retrofitting one of these into a small freezer under fridge for 24v opp..
http://www.danfoss.com/Products/Cate...3a5b95ca0.html
Old 06-29-2011, 11:11 PM   #11
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I have two 12V batteries for storage, solar panels to recharge and use the DanFoss fridge on 12V as well as the water pump and lights. Also can charge all my electronics using DC adapters without the loss of a converter.
Bill
101Z0203 - Product specifications - Danfoss
Old 06-29-2011, 11:28 PM   #12
Darkspeed's Avatar
1972 31' Sovereign
Bill
Bill which fridge do you have?
I was also looking at this one @ AVG 40W/H - can be had in the $1200 range
Sure Marine Service, Inc. * Since 1972 * Marine Heating, Air Conditioning, and Galley Equipment
Old 06-29-2011, 11:36 PM   #13
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
24v is fine until you run into a need to cross pollinate with the rest of the world, then it might get a little "interesting". Do you run your tow vehicle on 24V too, the umbilical will be a little confused for most 12v TV's
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 06-30-2011, 08:32 AM   #14
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
The one which is about 9CF.
Bill
Winterizing & Water Pump Access 27FB DMT Winterizing, Storage, Carports & Covers 28 11-17-2011 06:15 PM
Flojet or Shurflo Fresh Water Pump? SilverCottage Water Heaters, Filters & Pumps 8 07-24-2011 02:25 PM
Fresh Water Pump moosetags Fresh Water Systems 5 05-31-2011 07:08 AM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
