Old 06-30-2011, 11:04 AM   #15
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I'm doing the same, going 24V, and have found two Shurflo 5367131 24V Extreme Freshwater Pumps (used) off of eBay. Only took two years of looking for them to come up for auction and I think I paid $60 to $75 each of them.
I've got a Vitrifrigo with the 12/24V Danfoss compressor and I think the inverter module runs a little cooler on 24V, keep it clean and cool and they last a long time - let them get dusty or without at least some fresh air 'chimney' type air flow its an expense repair. I've also got a yachty built-in BD50 unit salvaged as a spare.
I committed to 48VDC for renewable energy systems a little too early - now am stuck piecing together 24V.
I did find a boost 12-24V 3-stage battery charger, made to install near TV battery, (The better to keep line losses down) for charging while towing or emergency top-offs when boon-docking. I'm also using its 24V quick-disconnect at the A-frame as input for portable solar panels.
Thirty-feet-plus of 4awg at 12VDC & 40 amps is 5% wire run losses (one advantage to having batteries on A-frame, they're closer!) but my batteries are going above the axles, So I can reduce the wire size to 8AWG.
After all is said and done the alternator-charger-battery wire run will be nearer to 40 feet and I'd hate to use anything as heavy as 2 or 4awg beyond the built-in trailer circuit!!
Old 06-30-2011, 12:41 PM   #16
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Cool! I really like the big Vitrifrigo. Those are super nice and look really good.
Sounds like quite the setup!
Darkspeed is offline   Reply With Quote
Old 07-28-2011, 07:23 PM   #17
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Originally Posted by Darkspeed View Post
Any advice on the best quality pump ?
The Flojet Sensor VSD runs on either 12v or 24v. Look it up and you'll see. Hve used one for 7-8 years now, very happy with function and noise level
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Winterizing & Water Pump Access 27FB DMT Winterizing, Storage, Carports & Covers 28 11-17-2011 06:15 PM
Flojet or Shurflo Fresh Water Pump? SilverCottage Water Heaters, Filters & Pumps 8 07-24-2011 02:25 PM
Fresh Water Pump moosetags Fresh Water Systems 5 05-31-2011 07:08 AM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
