Old 10-24-2015, 07:05 AM   #1
2010 23' Flying Cloud
High point , North Carolina
Moen Choiceflow 9600 water filter
Our 2010 flying cloud has a Moen Choiceflow 9600 water filter under the sink and the faucet has a separate on/off handle for water from the filter. Since we run everything through an outside water filter I wonder if there is a cap/bypass that can replace the filter. 2 reasons......1. it would give me some extra space under the sink for kitchen stuff...and 2. when I winterize wouldn't the pink stuff fill up the water filter. Or... is there a bypass valve that would shut off city water flow to this filter? I didn't see one near the filter itself.
Gmutt is offline   Reply With Quote
Old 01-01-2016, 06:48 PM   #2
Snaken49's Avatar
2010 28' Flying Cloud
Fort Worth , Texas
You can remove it and cap off the line. But you will lose the ability to filter the water that comes from your fresh water tank.
I only used the antifreeze once and decided it is too much trouble to add and then remove from the water system. I keep my trailer ready to roll year round and run the heater at 40 degrees in freezing weather do to 10 degrees without a problem.
Airstream recommends draining all the water out of your trailer for longer term storage. See the link below for detailed information.
http://www.airstream.com/wp-content/...terization.pdf
Old Cobra AH-1G Pilot
WoundedWarriorsFamilySupport.Org
http://www.highfivetour.com/
Snaken49 is offline   Reply With Quote
Moen - Water Filter Drathaar Winterizing, Storage, Carports & Covers 2 11-08-2013 08:03 PM
Moen drinking water filter Bbelk General Repair Forum 2 09-18-2013 03:55 PM
how to remove moen undersink water filter on 2010 bambi dsrtgrls Water Heaters, Filters & Pumps 5 12-06-2009 07:38 AM
2006 Classic Moen Faucet Filter Pappy Water Heaters, Filters & Pumps 18 10-02-2006 10:54 AM
Moen 601 water filter jcanavera Water Heaters, Filters & Pumps 3 04-04-2006 09:29 PM
