Old 04-18-2009, 04:58 AM   #15
Airstreamer since 1958
Stickbug's Avatar
1973 31' Sovereign
Greencastle , Pennsylvania
Dietz645: Mine looks different than that (pic to follow asap), but the blurb on the key said it fit 70's AS, so we'll wait for the mail to arrive and see. Before we're done I may have a complete set of AS water fill keys! The revelation that repro keys might save me from having to drill out the lock is a godsend, so thanks, even if the first one isn't the right one.
Lumatic: I have a center bath, so there's no place in the bathroom to put a Univolt that I can see. Could that account for the difference? The "under oven" looks like a factory job, but I can't be 100% sure.
Dan: I've tried all the keys I have, several of which are compartment keys, and they have different ... what do you call those lines that run the length of the key that make one blank different than another blank? We'll post a pic of our door asap and maybe that will help clear up some variation in this puzzle.
Thanks, all!
Doug
Doug Dobbs
Greencastle, PA
www.dougdobbs.com
Stickbug is offline   Reply With Quote
Old 04-24-2009, 06:18 AM   #16
Jared129's Avatar
1976 31' Sovereign
2014 28' Flying Cloud
1992 34' Excella
. , Maine
Reading all these posts kinda makes me feel better about the set-up on my '76 now. I always have wondered why the H20 pump, filter, and Univolt/fuse panel were all located within a few inches of each other.....made me nervous- at least now I know I am not alone
Jared and Heather
WBCCI # 4998
AIR # 24449
Jared129 is offline   Reply With Quote
Old 04-24-2009, 07:00 AM   #17
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
In both my 72 and 73 rear bath floor plans water pumps are located under the galley sink just above the floor on a platform common to the furnace? Also the Univolt & fuse panel are safe and conveniently located at the bath tub in the aformentioned microclaustionatious (wow; speel check likes that one) locker, the stand on your head under the bed fuse check one...
Old 04-24-2009, 08:25 AM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That could indeed. the center bath is exceedingly rare in 1970's-era coaches, and they are configured differently. Since it's a center bath, I am guessing you have a shower instead of a tub. If so, there would be no room for the Univolt under the tub, since there isn't one. They had to put the thing somewhere, and I guess under the oven is the somewhere they put it.
I have a suggestion, which is wotrth what you are paying for it: When you put a water pump in that spot, try to find a piece of old inner tube, or something else waterproof, and place it between the pump and the Univolt. It will reduce the chance of water spraying into the Univolt, should water start leaking under pressure. Murphy's corrolary says if it does leak, it will leak in the direction of the univolt.
Old 04-25-2009, 07:17 PM   #19
Stickbug's Avatar
1973 31' Sovereign
Water fill flap key - water fill key flap?? :)
Ok, got a pic of the errant child of a water fill opening. Should have done this first, sorry. Live and re-learn, I say.
Here's the big picture of what I'm working with:
Here's a close up of the company label:
Here's a closeup of the key slot:
The key I bought online isn't the right one, I think, but I'll have to go online now and see what else they might have available. I hadn't realized until today that it was a Thetford door. That might be a clue/help in getting the right key... ??
More replies in a moment.
Doug
Doug Dobbs
Greencastle, PA
www.dougdobbs.com
Old 04-25-2009, 07:32 PM   #20
Stickbug's Avatar
1973 31' Sovereign
Terry,
Yes, we have only a shower, no tub. Wasn't aware that center bath was so rare. That would explain why few have this setup. Murphy and I are old friends. He visits me regularly. Between house building and Airstream prep, I also shave a LOT of yaks.
I love the idea of the truck innertube buying me a little separation between the water and the juice, thanks.
Jared,
Glad we could be of help. Nice to know I'm not the only one.
Hope the pictures above move me one step closer to a solution on that issue. Hope to get to the pump installation problem next week.
Doug
Doug Dobbs
Greencastle, PA
www.dougdobbs.com
Old 04-25-2009, 07:59 PM   #21
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I bought the A/S minus a water pump. But now I can't seem to figure out where it would fit into the space it should go. Anyone with a similar rig that could take a pic and show me?
I'm not sure if this will help, but here are some photos I took of our '74 Sovereign as I was gutting it.
ID:	79250   Click image for larger version
Name:	water hole closeup.jpg
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 04-25-2009, 08:06 PM   #22
Stickbug's Avatar
1973 31' Sovereign
Retry on those images, larger versions...
When I checked that post I just made -- the URL doesn't seem to connect.
Let's see if we can do it another way...
Doug Dobbs
Greencastle, PA
www.dougdobbs.com
Old 04-25-2009, 08:10 PM   #23
Stickbug's Avatar
1973 31' Sovereign
Grant,
That is VERY helpful, indeed. Looks like the Univolt is to the right and the pump to the left, essentially reversed of what mine appears to have been, but it does give me some ideas. Never a dull moment!
Doug Dobbs
Greencastle, PA
www.dougdobbs.com
Old 04-25-2009, 10:48 PM   #24
Well Preserved
1993 21' Sovereign
The key you need will be double-sided, with the same pattern on both sides. It will only fit one way, though, because of the rib in the center.
Old 04-27-2009, 05:49 AM   #25
Roblin , MB.
Milton,In your photo it appears you may have a 36800 - 1000 Par Pump. Was wondering if you still use it and how it works for you. We purchased one on eBay for our 74 Sovereign and will be installing it shortly.Bob
nairnchyz is offline   Reply With Quote
Old 04-27-2009, 06:37 AM   #26
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Doug,
Take a look at this link. I think Dan from Out Of Doors Mart also posted this link to the key. The associated pictures look just like the ones you posted...
Water Fill Key WF-01 - $5.95 : ODMRV , Out-of-Doors Mart
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 04-28-2009, 05:16 PM   #27
Stickbug's Avatar
1973 31' Sovereign
Yep, that's what I remember the old key being, double sided. Thanks!
Doug Dobbs
Greencastle, PA
www.dougdobbs.com
Old 04-28-2009, 05:18 PM   #28
Stickbug's Avatar
1973 31' Sovereign
Deitz,
Yep, that looks like the ticket, all right. I've sent in an order for two, so I'll have a spare. Also some door key blanks so I don't lose my one and only copy and get locked out of my aluminum igloo!
Can't tell you all how much I appreciate this help.
Doug
Doug Dobbs
Greencastle, PA
www.dougdobbs.com
Missing lower washroom panel, side bath '76 31' Sovereign TobyJH 1974 - 1979 Sovereign 2 04-01-2008 11:05 PM
Missing support arm for 31' 76 sovereign chris's 67 Awnings 3 01-31-2008 05:48 AM
rebuild kit for water pump 76 sovereign chris's 67 Fresh Water Systems 2 03-06-2007 08:18 PM
What full hubcaps fit 1973 Sovereign? greenacres Brakes & Brake Controllers 1 08-20-2004 10:20 PM
How's I-81 Over59 On The Road... 10 05-15-2004 08:03 PM
