I know Steve pretty well and carry his product. When we started getting calls from Airstream owners claiming their readings were off, I started to question the system.
As it turns out, he calibrates them at the factory before they are shipped to OEMs and if they change the design/shape of a holding tank for a new model, guess what....yep the readings will be off. Certainly not his fault and I presume some frustration when manufactures assume there is a generic calibration.
Regardless if anybody has the system and inaccurate readings, the calibration procedure is simple. I think its in the manual if Airstream provided you with one.
In the end its a good product and I like the new LCD version coming out.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
