Old 05-17-2004, 06:38 AM   #1
JohnGalt48's Avatar
1977 31' Sovereign
Exclamation Major fresh water tank leak!
I just sanitized my water system with the bleach/water method recommended here.
I had noticed a very minor fresh water leak the last couple of years, but it seemed to just happen for a little while when the tank was full. I could see an occasional drip at the corner of the "dropped" section of the belly pan where I'm assuming the fresh water tank is.
After sanitizing, now that drip is almost a stream and I've lost the whole 50 gallons of water in two days!
I checked the hose connections that I can reach from inside the kitchen cabinet where they go to the tank, and I don't feel anything there.
Is there a common place for the fresh water tank to leak? Is the tank itself known to develop fatal leaks? Are replacements available? What kind of a pain is that??
I'm getting ready to leave for a 3 week trip to the Southwest this Friday, and now I'm a bit panicked.....yikes!
Guy
JohnGalt48 is offline   Reply With Quote
Old 05-17-2004, 07:17 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
guy
fatal leak? maybe not, here is how i repaired mine http://www.airforums.com/forum...ead.php?t=5206
your trailer may require cutting an access hole in the belly pan (unless you already have one). the trick is where. i belive your trailer has a internal drain valve, so looking in from above may give a clue where to cut a hole. mine came from the factory with a access hole. my leak was due to a cracked fitting and a disintergrated 1 1/2" main drain plug.
once you get at it, the repair may be easy as mine was.
good luck
john
you call them ferrets, i call them weasels.
Old 05-17-2004, 06:50 PM   #3
JohnGalt48's Avatar
1977 31' Sovereign
Hi John....
I just got home and....yep.....got a beer!
I don't think my trailer has a drain valve and plug like yours. No mention of it in the service manual, and I sure don't see anything under there that looks like what you've got.
There is a large bolted on "support pan" that sticks down below the thin aluminum belly pan that apparently supports the tank. The leak is running out of a corner of that, so I guess the leak could be anywhere in the tank.
I suppose I'm going to have to pull that to see what's up. I don't really have time before my trip for a tank replacement, so I'm hoping that it's something minor that I can fix with one of those plastic tank repair kits if it's the tank itself.
Otherwise, dry camping is out for this trip and that's kinda sad....
Worst case, does anyone know if new tanks are available?? Andy??
Guy
Water leak from Holding Tank Drain gwilliam Fresh Water Systems 5 04-18-2010 07:45 PM
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 05:25 AM
Water Tank Leak - broken part suggestions? gklott Our Community 3 05-02-2004 04:53 PM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 09:16 PM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 03:10 PM
