Old 03-21-2011, 08:40 PM   #1
1997 30' Cutter Bus (Ford)
grosse pointe , Michigan
Cool Low water pressure
I have a 97 cutter. water pressure is low. pump seams to be on a lot like there might be a leak. how do i start trouble shooting?
cutbrain is offline   Reply With Quote
Old 03-21-2011, 08:49 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If the pump cycles on and off when there facets are all closed, you have a leak or the check valve in the pump is bad.
Richard
Old 03-22-2011, 04:35 PM   #3
where do i find the check valve in the pump?
Old 03-22-2011, 04:43 PM   #4
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
You might also have worn out pump diaphrams, especially if the pump doesn't have an inlet filter. The pump head can be replaced without replacing the whole pump. Depending on the make you might be able to find parts at Camping World.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 03-22-2011, 06:21 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Before you start taking things apart try this.
Run the pump till it shut off. Wait a few minutes an turn a faucet on. If the initial flow is light I would look at the aerators on each of the faucets for lime deposits.
2004 Excursion 4x4
leaks, low water pressure, plumbing
Another Water Pressure Question lsmith Fresh Water Systems 3 04-03-2011 09:20 PM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 12:00 PM
Discovered how to increase water pressure! HCR Fresh Water Systems 6 01-15-2011 01:50 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
