Old 08-29-2014, 09:26 AM   #1
john4170's Avatar
2014 16' Sport
Chicago , Illinois
Low point valve leak
Woke up this morning to the water pump cycling on and off. Come to find out, one of the low point valves is leaking and there doesn't appear to be enough room between the bottom of the tank and the valve to tighten or remove to install plumbers tape. Any suggestions? Click image for larger version
Name:	ImageUploadedByAirstream Forums1409325897.907985.jpg
By the way, we have a 2014 rear twin 25ft flying cloud
john4170 is offline   Reply With Quote
Old 08-29-2014, 10:29 AM   #2
1974 Argosy 20
Kooskia , Idaho
There is a 2 year warrantee on your rig, so let an Airstream Dealer solve the problem. You paid for that.
Old 08-29-2014, 01:17 PM   #3
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
We had the same problem with our 2012 FC, only when I touched it , the whole thing fell off. I used JB Weld to seal the hole until I could take it to Jackson Center for a repair under warranty.
Castaway is offline   Reply With Quote
Winterizing snafu - low point drain valve on FW tank stripped and won't opem bonginator Fresh Water Systems 12 09-29-2013 02:22 PM
Replacing the low point water drain valves thecatsandi Fresh Water Systems 4 02-17-2009 11:32 AM
front low point drains, 19' int'l ericwarren Winterizing, Storage, Carports & Covers 3 12-18-2008 02:58 PM
Low point drains runningbarre Winterizing, Storage, Carports & Covers 5 09-25-2008 06:07 AM
Failure of low point drain valve? desidou Fresh Water Systems 8 12-24-2006 08:29 AM
