Old 08-09-2010, 01:07 PM   #1
2002 30' Classic
Sudbury , Ontario
Question leaky water pipe
I have a 2002 30' Classic that has a water leak.The water is dripping from the access plate that is under the water tank, it is a small drip that occurs when city water is on or when the pump is on. When inspecting the area around the pump it is dry, as well as the area around the water heater. I know the water leak is from the cold water supply and is not anywhere in the trailer. Has any one experienced this problem and where can I access the trailer to find the leak.
favretb is offline   Reply With Quote
'71 Overlander Leaky Pipe LCHolloway Fresh Water Systems 6 04-29-2009 06:49 PM
Leaky hot water tank Dan S All Argosy Trailers 4 04-06-2007 06:43 AM
Leaky Black Water plus... altastars Waste Systems, Tanks & Totes 1 07-10-2004 12:10 AM
leaky water tank etc. norbert 1993 Excella 1000 4 10-22-2003 03:22 PM
