Old 04-11-2009, 01:55 PM   #1
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
Leaky thing replaced, new one leaks too
http://www.chrisandannette.com/Airst...5/P1010016.JPG (larger pic)
The red handled drain valve that came with the trailer was leaky, so I replaced it with the pictured one which leaks too when open for draining. It dribbles out the top and from the little spinny thing on the side too.
The only thing in common between the old one and new one is me , so what did I mess up?
Do these things melt inside if you torch them too much or something?
(I know the rubber drain tube is a bit tight on its corner there.. I will get back to that one with a copper elbow eventually..)
Thanks!
chrisd37 is offline   Reply With Quote
Old 04-11-2009, 02:05 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Give it a little time for the washers to seat themselves and the leak may stop. If it still leaks take off the little spinny thing and your will find a phillips head screw you can tighten a little. If that doesn't work take a wrench and remove the valve stem and replace the washers. You should not have to replace the whole leaky thing.
Old 04-11-2009, 02:06 PM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Looks like the replacement job I did once on our rig, same location.
The only problem I could find was that the replacement drain valve was of poor quality. It was the only one for sale at the hardware store.
Oh, and Made in China.
Now that whole area is made of Pex. I don't know where it was made, but at least it doesn't leak.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 04-11-2009, 02:17 PM   #4
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
I will give that screw a try thanks.
Replace the washers... are they rubber or some other material i might have melted? I could've melted the old one too. The old pressure regulator was being too effective and had to be replaced to get a pressure above zero. That caused me to torch everything there at least twice..
Old 04-11-2009, 02:24 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Rubber or plastic. I imagine it is possible they were damaged by the heat. They are strictly standard hardware store issue and very cheap. Take the valve stem with you to the hardware store so you can match up the right washer.
Old 04-11-2009, 03:20 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Here is a good tip for future work:
Remove the inside pieces of the valve when you are installing it. The top piece should unscrew and all of the piece that can and will melt can be removed.
Pull it apart now and replace any of the damaged pieces.
Richard
Old 04-11-2009, 03:24 PM   #7
Kevin245's Avatar
Try tightening the packing/jam nut under the red handle.
Eleanor Roosevelt
Old 04-11-2009, 06:35 PM   #8
1976 31' Sovereign
Oswego , Illinois
where is valve located as I have never found setup as pic? only way I can drain tank is with water pump. I pur. 76 31 sov new in 76 my other 5 prev as 1 argosy all had tank drains I do not winterize put in heated mach shed saves lot of work and worry about freeze up thks. farmer bill
Old 04-11-2009, 06:58 PM   #9
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
Hi farmer Bill, it is in the very rear of the trailer on the road side. It's a center bath setup that had twin beds in the rear bedroom. That stuff was all under one of the beds.
Kevin245, that part is tight. Leaks anyway.
Old 04-11-2009, 07:03 PM   #10
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
farmer Bill here is a better pic for seeing where all that stuff is located:
http://www.chrisandannette.com/Airst...5/P2010012.JPG
It does match my service manual, so I think it's where it goes.
Old 04-11-2009, 07:21 PM   #11
SaabLover's Avatar
Almost Always Sunny Sarasota , Florida
Images: 12
I think you would do well by replacing the valve seals. I always remove the the inner valve when soldering it in to keep it from burning. It should only cost a couple dollars.
By the way which Saab is that in the window? I have a 1992 900 convertible.
1999 Chevy Suburban 7.4LT "Tugger" Last of the big boys! Still going strong. 1992 Saab 900s Convertible 60K miles Not my TV
Almost always sunny here unless there is a hurricane bearing down on you. And then it's time to hook up the burb and roll. So far I've been very lucky.
SaabLover is offline   Reply With Quote
Old 04-11-2009, 07:54 PM   #12
1963 24' Tradewind
San Diego , California
Number of reasons for leak, heat damage, debris under the washer, defective valve. I prefer the ball valve their maintenance free instead of the rubber washer type that need maintenance.
Good Luck!!
Sixty3TW4US is offline   Reply With Quote
Old 04-11-2009, 08:13 PM   #13
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
I'm sure I must have melted its innards. I am going to pick up another new one of these valves and stick its innards in the previous new one. If that doesn't fix it, uh...
SaabLover, too funny. I saw your name and wondered if you looked out the window of my Airstream pic. It's a 1987 turbo convertible, my other project for while I wait on Airstream parts!
Here are a few pics the day the Saab came back from getting some body work and a paint job WebForm1 and here I am suffering through installing 4 springs and 4 Bilstein HDs WebForm1 .. Next up is a Garrett T3/T4, fancy wastegate, rising rate FPR, performance fuel pump, redtop injectors, fmic, new vinyl seatcovers all around, new to me door panels and window seals etc etc etc... I got my 2nd APC in the mail the other day from Ebay.. Will be tweaking!
Old 04-12-2009, 10:09 AM   #14
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
farmer Bill, maybe I am confused as to what sort of trailer I have? It says Sovereign on it but it also says Land Yacht. It has an "I" VIN which sounds like an International. The blue wraparound stickers claim it's an Excella. All I *know* is it's 31' with a center bath and rear twin beds, manufactured in late 1975 for model year 76.
Replaced Valances GoldFever 1990 - 1993 Excella 18 06-05-2008 08:19 PM
Replaced our stove Buttercup Stoves, Ovens & Microwaves 11 04-07-2006 10:53 AM
Awning Replaced Herritt Awnings 3 08-16-2004 07:34 AM
Replaced Voyager--what to do with it? Kistler Our Community 7 01-19-2004 05:28 PM
How many axles replaced Jabba Axles 7 10-21-2002 01:21 PM
