02-08-2007, 04:13 PM
2003 31' Classic
Valparaiso
, Indiana
Leaky Freshwater Tank
Help!
Finally got to Florida only to find out my freshwater tank does not hold water.
Need to repair or replace. How difficult a task is this?
98 31' excella 1000. luckily I don't need it right now, but will in the not too distant future.
Thanks for your help.
Bob Adney
I can win an argument on any topic, against any opponent. People know
this, and steer clear of me at parties. Often, as a sign of their
great respect, they don't even invite me.
Bob-air # 657
I can win any argument on any subject. People know this and steer away from me at parties. Often as a sign of their respect, they don't even invite me.
02-09-2007, 03:36 AM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
Originally Posted by rochar3
Help!
Bob Adney
Sorry, can't help, but saw this so I figured I'd bump it up for ya. Good Luck!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
02-09-2007, 06:49 AM
Retired.
, At Large
Is the drain valve closed? It seems too simple, but I would try moving it and see if the leak stops.
02-09-2007, 07:27 AM
St. Cloud
Sometimes the drain valves go bad. Believe john hd put up a thread on replacing his...
02-09-2007, 08:29 AM
Desert Fox
1985 31' Sovereign
Tucson
Leaky Tank
Hi,
My fresh water tank leaked only when I drove. I had to take it out and replace it. It is about a days work if you have a floor jack.
The tank was crakedf on top from end to end. That is why it leaked only when I over filled it or went around a corner.
The biggest pain was on how to hang the new tank and hook it up. I did what the factory did use duck tape.
Regards russell in sunny Tucson Az.
02-09-2007, 09:48 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Definately better than a black tank leak...not as odoriferous but almost as annoying.
It would help if you could tell where it's leaking from...it may be a simple repair, a loose fitting or it might require a new tank completely - depending on the source.
I know you aren't "vintage" yet, but this page of resources is great! Check out Inca Plastics specifically. Although with a '98 I'd bet an Airstream dealer could get you a new tank from the factory...assuming it's the tank that needs to be replaced and not a drain or fitting which they could probably get as well.
Shari
02-15-2007, 05:05 PM
1992 29' Excella
Nashville
, Tennessee
When I bought my 92, I also had a fresh water leak. Expecting the worst, I dropped the inspection plate on the driver side, by the drain valve. Luckily, all that was wrong was a split plastic hose between the tank and the drain valve. The valve is a couple of bucks and you can get the hose at Lowes/Home Depot.
Hope your's is as easy as that. I expect mine wasn't properly winterized (completely drained) by the PO.
