Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 05-31-2008, 09:02 AM   #1
tomcook's Avatar
Profile:  1992 34' Excella
Salem , Virginia
leaking tank - 1992 34' Excella 1000
An "on site" mechanic familiar with Airstreams says my fresh water tank leak is not a valve or connection.
When he tried to pull belly pan, he found it had been sealed with something that he could not break loose. After removing all the bolts, he bent a screwdriver trying to pry it free.
I've moved on and am considering trying to fix it myself but have some very basic questions.
First, how do you place it on jack stands when the only place safe to put weight is on the jack pad - which is occupied by the jack?
Second, is the sealant original or an overzealous previous owner? Any ideas on how to break the seal?
Anybody with experience in dropping the tank on a 3 axle?
Thanks.
Tom
tomcook is offline   Reply With Quote
1992 Excella 1000 purchase? lohidoc Member Introductions 1 05-17-2007 10:22 PM
1992 34' Excella 1000 w/suburban 4 Sale NEW2AS For Sale & Wanted 5 04-25-2004 01:05 PM
34' Excella 1000 needs cooler A/C cjholloway Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-17-2003 06:50 PM
1990 34' Excella 1000 LittleRadio 1993 Excella 1000 1 10-22-2003 05:25 PM
Rims For a 1992 34' Excella NEW2AS Wheels 1 04-07-2003 03:53 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
