Old 07-29-2006, 11:16 PM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Leaking Fresh Water Tank
I have a 77 Argosy. The fresh water tank is at the front of the trailer under the sofa. I have notice that when I fill the tank all the water drains out the city water connection at the rear. Is there a check valve and where is it located?
gaylejoe is offline   Reply With Quote
Old 07-29-2006, 11:39 PM   #2
GreatPumpkin's Avatar
Colville , Washington
Images: 70
There should be a check valve, but no telling if it's still there or has been removed by a P.O. (previous owner) without tracing the lines from front to back. By the sounds of it, you do NOT have a check valve, as it would prevent the scenario your are describing.
A quick-n-easy fix is to put a plug in the city water connection - you should do this anyway to prevent dirt and critters from entering your water system.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 07-30-2006, 05:35 AM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
On your Argosy, the check valve should be in the streetside rear corner, either inside the streetside closet, or under the bathroom counter, on the floor near the red water drain valves. Which brings to mind a question: Are the red valves all turned off? The water could be coming from there, or backfeeding from one to another, then draining out.
Old 07-30-2006, 08:50 PM   #4
gaylejoe's Avatar
St. Hedwig , Texas
Overlander, what are the red valves? We recently had a leaked fixed under the sink in the rear bath. Before that the fresh water never leaked out of the city water connection. We do have a plug that we screw into the water connection and it has a small hole in the center. That's how we noticed the water leaking. What are the red valves for? Please feel free to call me at 210-860-6006.
Old 07-31-2006, 07:37 AM   #5
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
If you find it is the tank, I have one from a '73 that may fit. PM if you are looking for a replacement?. Good Luck with your repair.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 07-31-2006, 07:49 AM   #6
1993 21' Sovereign
The red valvrs are used when winterizing, and are opened to drain the water lines. If one or both are open, it could cause this problem.
Old 08-02-2006, 08:57 PM   #7
gaylejoe's Avatar
St. Hedwig , Texas
I greatly appreciate all the information. I will go out tomorrow and try to locate the red valve. I will let you know if it is the check valve.
Old 08-08-2006, 11:21 AM   #8
gaylejoe's Avatar
St. Hedwig , Texas
Regarding the drain valves for the water, when are the lines open or closed? Are the valves turned all the way clockwise or counter clockwise????
Old 08-15-2006, 08:05 PM   #9
gaylejoe's Avatar
St. Hedwig , Texas
Regardless of which way I turnd the drain valves the water continues to drip through the city water connection from the fresh water tank.
Which way are are the drain valves turned to open the lines?
Old 09-30-2006, 07:04 PM   #10
2019 22' Sport
High River , Alberta
clockwise to close
Turn the red valves clockwise to close, counter clockwise to open. I know because I just used mine today.
AlbertF is offline   Reply With Quote
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 12:43 PM
Sanatizing the Water Tank? 68 Suburban Fresh Water Systems 3 10-13-2002 12:22 PM
What Grey Water Tank?? niftypkg Waste Systems, Tanks & Totes 6 09-04-2002 07:12 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
