Old 08-18-2019, 07:56 PM   #1
2015 25' FB Flying Cloud
Minnetrista , MN
Leaking fresh water tank
I have a 2015, 25' Flying cloud with a dripping fresh water tank. There is a small hole (about 2mm) on the passenger's side at the front of the tank that constantly drips water. It looks like it is intentionally placed there but I haven't had a leak in the past. Can anyone tell me what it's function is and what should I do with it? What material works the best to seal it up? Thanks
Wesair is offline   Reply With Quote
Old 08-18-2019, 08:16 PM   #2
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Can you post a pic? Something above that tank pan is leaking into the pan and coming out through that opening, so you need to find the source of the leak, not seal up the hole in the pan--the water will just start leaking out somewhere else.
This could be many sources...leak in the tank; leak in a fitting somewhere above the tank, such as the water pump or relating fitting, or other sources. Does this happen with the pump on only? Or when pump off and depressurized as well? Also on City water? If fresh tank is empty?
Will need to do some troubleshooting to help you with this one...and a pic would definitely help too.
pcskier is offline   Reply With Quote
Old 08-18-2019, 08:17 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Belly pan/ tank shroud is not the tank. It’s a cover. Tank is polypropylene and located inside the shroud. The drip you have could be a tank leak or just a plumbing leak.
Questions...
Does it leak all the time or only when connected to city water or pump on?
Read my blog post as it’s a good place to start. Even though mine is a 23D it contains many photos of what the heck is going on inside your Airstream.
http://www.airforums.com/forums/blog...lacement-2929/
http://www.airforums.com/forums/blog...t-part-2-2930/
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 08-18-2019, 08:18 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Originally Posted by pcskier View Post
Can you post a pic? Something above that tank pan is leaking and coming out through that opening, so you need to find the source of the leak, not seal up the hole in the pan that you can see.
Pics would help..
Old 08-18-2019, 08:58 PM   #5
Minnetrista , MN
Thanks for the quick replies. I didn't realize that the tank was actually covered by the pan! It is good to know and it also means that I have more investigation to do. The job just got considerably bigger and I don't think I'm up for dropping the plan plus it doesn't help that I'm 1000 miles from home. I will let you know what I come up with. Thanks again.
Old 08-18-2019, 09:17 PM   #6
FishByFly's Avatar
2017 25' Flying Cloud
Fayetteville , Arkansas
AC condensate? Just a question.
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn
2023 F150 XLT
FishByFly is offline   Reply With Quote
Old 08-19-2019, 05:36 AM   #7
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Just make sure you don’t seal that “drip hole” as you will be doing nothing more than hiding the problem.
Old 08-19-2019, 05:53 AM   #8
"Cloudsplitter"
Plus if you fill compleatly up the tube it may 'weep' 'til it reaches the lower vent connection....AMHIK.🤔
Old 08-19-2019, 10:03 AM   #9
2013 27' FB Eddie Bauer
Salado , Texas
I had the same problem and if it is occurring when the system is unpressurized it is likely the place where the hose interacts with the tank. Our dealer in Buda TX told us that they had a flurry of those in the past couple of years. They applied an epoxy to make a seal around the connection point to save me the cost of a water tank replacement. It has held up for about a year now without a problem. If that did not work I would have had to replace the tank.
Loden is offline   Reply With Quote
Old 08-19-2019, 02:15 PM   #10
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Are you connected to CITY water? If so, you may have a blocked or defective check valve. Happened to me. I'm having dealer install a sharkbite check valve between fresh water tank and pump.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 08-26-2019, 05:48 PM   #11
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
My fresh water tank has a vent on the top right corner. Its not visible from side or bottom but if its on a rack, you can see it with a flashlight. I discovered it while filling my tank and it started to run out the bottom. Thought my fill line was busted but it was the overflow vent just doing its job.
Mike1997 is offline   Reply With Quote
Old 08-26-2019, 07:28 PM   #12
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Use some food coloring and take some pics!! DO NOT USE YELLOW!
Steve
1958 California Built 18' #18-4092
https://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 08-26-2019, 08:44 PM   #13
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
We had a similar problem with our tank last year. I took Trixie back to JC for a new tank. The drain fitting bung had a small crack that would leak when pressure from a full tank pressed against the fitting.
After repairs, the tank leaked again, and another trip to JC. Apparently this time, both the fill tube and the vent tube were not seated or sealed properly.
You can easily check the fill and vent tubes from inside the trailer. Under the refrigerator open the door and remove the inner panel. Look around the water pump and you should see an access hole that is right over the fresh water tank. Have someone fill your tank slowly and look for any leaks. If your lucky you will see a leak (or two). It's not a difficult fix, but it is a tight area. If this isn't your problem, then I think you will need to drop the tank for inspection and repair (and/or possible replacement).
Good Luck!
drew05 is offline   Reply With Quote
Old 08-27-2019, 08:45 AM   #14
abbotsford , British Columbia
most likely cause is around a sensor or fitting
telcoman is offline   Reply With Quote
Old 08-28-2019, 04:26 PM   #15
2011 23' FB Flying Cloud
Tigard , OR
Take a look topside near your pump with a flashlight you may well discover your problem without touching the pan.
Stinson.mr is offline   Reply With Quote
Old 08-30-2019, 08:36 AM   #16
Minnetrista , MN
Thanks for your suggestions. Since the original post I took it into an RV repair place and he believes all of the fittings are solid and that there is a leak in the tank. He didn't take off the belly pan so I'm not totally convince. I've now returned home, ordered a new tank (less than $200), purchased a motorcycle jack to lower and lift the tank (less than $100), and will take it all apart next week. I'll try and take pictures along the way. Thanks.
Old 08-30-2019, 10:08 AM   #17
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I will be interested in your progress. With the same trailer and same problem, I paid real money to my dealer to do the job. 11 weeks later they were finished. The delay was two-fold. First, just the wait time for dealer service, then they had the wrong tank and had to wait for one to arrive. Then more dealer wait time.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-30-2019, 11:17 AM   #18
"Cloudsplitter"
Thanks.
How long does it take to drain and how much...empty?
He didn't take the tank cover off, how did he confirm it was the tank and not one of the fittings or clamps?
Will the entire tank drain?
Was it filled a couple gallons at a time to determine when the leak starts.
My GT was leaking, as soon as I put two gallons in, it started, was it a hole in the bottom?...No, it was the drain valve, also on the bottom.
Old 09-04-2019, 09:24 PM   #19
2016 30' International
redondo beach , California
Well I have spent many days under the trailer working on the water tank.
I'll bet a beer the tank is OK.
On mine the weak link was the cheepo connection between the tank and the tank drain valve.
After that there was a pin hole in the very thin hose to used to fill the tank.
Be very careful not to overtighten the bolts holding the pan as they will strip. Use hand tools. Do not use a power tool there. Mine were all stripped from the factory or from the dealer.
This is a good time to replace the high density foam insulation as Airstream just tosses some random pieces in the tank housing for insulation.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 09-05-2019, 04:41 AM   #20
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
PM me if you have any questions.... I’ve been there.
Biggest thing to note is you probably WILL have to lift the trailer approx 5 1/2” to get the old tank out. Mine sat between the axles.
I jacked mine and placed the tires on 6x6 boards.
Also make sure you remove the bottom drain plug in tank. Just draining it normal leaves a lot of water still in the tank.
Help! Water Leaking into my Fresh Water Tank dasams Fresh Water Systems 15 06-21-2017 08:57 PM
Leaking fresh water tank Yorkrus Fresh Water Systems 5 08-19-2007 12:44 AM
Leaking Fresh Water Tank gaylejoe Fresh Water Systems 9 09-30-2006 07:04 PM
Anyone fixed a leaking fresh water tank? JohnGalt48 Fresh Water Systems 2 06-28-2004 01:59 PM
HELP fresh water tank leaking wvabeer Fresh Water Systems 2 04-08-2003 11:10 AM
