Old 09-07-2019, 06:12 AM   #21
2015 25' FB Flying Cloud
Minnetrista , MN
Here is a picture of the problem. There is a threaded fitting that is part of the tank that the water line connects to. The fitting was cracked at the joint where it connects to the tank. I'm not sure how it happened but possibly while driving down a bumpy road and it put too much pressure on the joint. I'm wondering if using a flexible pipe vs. pex would make sense?
I purchased a motorcycle jack to lower the tank and it worked great - less than $100 on Amazon.
There are 5 things to disconnect before the tank can be lowered. Large fill pipe held with pipe clamp. Small air vent pipe held with pipe clamp. Water pipe that leads to pump connects with threaded fitting. (This is the same fitting that is used to winterize with antifreeze). Two low water drains. I didn't see a way to disconnect the pipes for the low water valves so I had to cut the pex. Reinserting pex fittings in the tight space should be interesting. I had to purchase a pex clamp wrench ($60). Probably a one-time use.
There were screws, rivets, and assorted trash in the under belly. Rather sloppy I thought.
I'm now waiting for the new tank to arrive. (less than $200 from AS dealer).
Wesair is offline   Reply With Quote
Old 09-07-2019, 03:03 PM   #22
2016 30' International
redondo beach , California
I owe you a beer.
I used pex sharkbite type plumbing fittings where needed.
Otherwise I used flexible tubing and hose barbs/clamps to make life easy.
Some people paint the inside of the tank and replace the high density foam.
Use pieces of high density foam on all sides of the tank to secure it so it can't slide/move in any direction including the side with the plumbing.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 09-07-2019, 03:39 PM   #23
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
That’s what I did...
GMFL is online now   Reply With Quote
Old 09-07-2019, 04:12 PM   #24
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Make sure your drain is located where you want it and replace it with a decent valve.
sheriff1 is offline   Reply With Quote
Old 09-07-2019, 04:17 PM   #25
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Did that too. Relocated valve to between tires and replace cheap plastic drain with this sexy chrome plated brass one.
Old 09-12-2019, 07:15 PM   #26
Minnetrista , MN
The job is done so I thought I would send a few pictures. Some tanks come with sensors but mine didn’t. I very carefully used a heat gun to loosen the glue and a thin blade to slowly work underneath it. An RV tech told me he has 50% success saving them. There was enough glue on the back to reinstall but I added some duct tape for insurance. Test the wiring before you completely installing the tank. Also think very carefully before you cut PEX. AS uses copper crimping rings and for me they are not easy to remove. The bigger issue is potentially ruining pipe and fittings that can be inaccessible or difficult to replace. The motorcycle jack was a great help. Once I got a couple of bolts in the rest lined up pretty well. Fill tank, drink a beer, take an ibuprofen.
ID:	352043   Click image for larger version
Name:	tank and straps.png
Help! Water Leaking into my Fresh Water Tank dasams Fresh Water Systems 15 06-21-2017 08:57 PM
Leaking fresh water tank Yorkrus Fresh Water Systems 5 08-19-2007 12:44 AM
Leaking Fresh Water Tank gaylejoe Fresh Water Systems 9 09-30-2006 07:04 PM
Anyone fixed a leaking fresh water tank? JohnGalt48 Fresh Water Systems 2 06-28-2004 01:59 PM
HELP fresh water tank leaking wvabeer Fresh Water Systems 2 04-08-2003 11:10 AM
