Old 07-22-2008, 10:53 AM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Leaking check valve
The check valve in my water pump has begun to leak intermittently. When it does, water flows from the city water connection through the pump into the fresh water tank, eventually overfilling it and causing it to overflow onto the ground.
I know I can fix this by placing a check valve 'in front' of the water pump.
I always use a filter when connected to city water and when filling the fresh water tank so I don't think it is a matter of sediment interfering with the check valve built in to the pump. I also have an external pressure regulator in addition to the one built in to the plumbing so I don't think it is an over pressure condition.
My question is whether I should suspect a immanent pump failure?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 07-22-2008, 01:09 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Take the head off the pump and you should find a 4 valve rotor pump. You should be able to lift the valve off and see if there is dirt under it or if the rubber has failed. Not sure if parts are available.
The pump head is the check valve. If one of the valves is bad that is the one that is leaking. Depending on which valve is closed when you shut off the pump will determine if it leaks back to the tank.
2004 Excursion 4x4
Old 07-22-2008, 03:35 PM   #3
Area 63 Productions
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
Send a message via Skype™ to Area63
Not necessarily. I would try the check valve idea, and what Howie E said.
Uwe
www.area63productions.com
Area63 is offline   Reply With Quote
Flush valve leaking Loren Waste Systems, Tanks & Totes 7 11-06-2013 08:47 AM
Blackwater tank valve leaking... Ketchum Waste Systems, Tanks & Totes 7 07-20-2008 06:47 PM
Leaking Dump Valve dblee50 Waste Systems, Tanks & Totes 34 11-24-2007 05:28 AM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
Leaking valve Gene Wissink Plumbing - Systems & Fixtures 11 08-31-2005 10:05 PM
