JDL,
The only useful piece of information that I received from the dealer where I purchased my CCD was this:" the city water inlet fixtures are prone to leak".
Everything else that they told me proved to be BS. Mine has not leaked yet, but I would suggest getting a new one from the factory under warranty , or having your dealer replace it PRONTO!
BTW, are you using a pressure regulator at your supply spigot that is set between 40-50 psi? If not, the high water pressure from the tap might be adding to the problem.
lewster
