Old 08-08-2006, 07:22 PM   #1
JDL
JDL's Avatar
2005 19' International CCD
T , Oregon
Unhappy Leak Under City Water Connection
Hello,
I took my (new to me) 19' 2005 Bambi CCD out for its maiden voyage last weekend. Much to my dismay I discovered a leak when the city water was connected. Specifically, there was a small consistent drip of water coming from the small light fixture just below the shore power coupling. (This is the one used to illuminate the dump valve at night.) I noted this water continued down along the side and exited at the rear of the bumper. Not heavy but just a consistent drip along the way. It was defiantly not gray water or black water. (How do I know? I caught a cup of it over night and... I sniffed it... ) I assure you it was clean ‘city’ water.
1. This only seems to occur when the trailer is hooked up to 'high' pressure city water.
2. When using the internal water supply and the pump is on -- the pump does NOT cycle - So no loss of pressure in the internal system.
3. Its not running down the outside of the trailer... (Obviously it is on the inside somewhere...)
It’s at the dealer now. I was just curious if any one else has seen this and knows what it is? Ideas? Is it the pressure regulator? Gremlins... bad karma…
Do I need to worry about the floor boards or mold?
JDL is offline   Reply With Quote
Old 08-08-2006, 09:42 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 101
What ever it is.... you need to track it down. Over time it will get worse and eventually you may have moisture issues - but based on the volume you described - it'll dry out this time, with no harm done.
Anyone have any ideas to track the leak?
1964 Globetrotter | 2023 Nissan Armada
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 08-08-2006, 10:04 PM   #3
Naples , Florida
JDL,
The only useful piece of information that I received from the dealer where I purchased my CCD was this:" the city water inlet fixtures are prone to leak".
Everything else that they told me proved to be BS. Mine has not leaked yet, but I would suggest getting a new one from the factory under warranty , or having your dealer replace it PRONTO!
BTW, are you using a pressure regulator at your supply spigot that is set between 40-50 psi? If not, the high water pressure from the tap might be adding to the problem.
lewster
Old 08-09-2006, 02:45 AM   #4
JDL
JDL's Avatar
T , Oregon
Hey Lewster,
Thanks!
I suspect this has been going on for some time. I do not think the previous owner knew about it.
Its in the shop. I should know more this week. I told them to check for mold etc..
I did not use a pressure regulator at the supply spigot that is set between 40-50 psi. Per the manual they have one that is internal for the trailer? I guess I will need to get one?
Old 08-09-2006, 12:00 PM   #5
Frank S
peoria , Illinois
Hi JDL--A pressure regulator (Marshall Brass $8 at WalMart) at the supply spigot will also protect your hose, and minimize leaks in all connections up to your A/S.--Frank S
Frank S is offline   Reply With Quote
Old 08-09-2006, 03:23 PM   #6
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
The old style water pressure regulator in my '79 Excella dumps pressure (and water) overboard through a hose if the supply pressure is too great. I, too, use an external regulator bought at Wal-Mart just to stop the pressure dumping (and the puddle under the trailer).
I wonder if that's what you're seeing on your 2005?
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-09-2006, 04:14 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Just another thought, in my current trailer I also had a drip in the same area when under city pressure. It ended up being a water heater connection that can be tightened by hand. I had the trailer up at the dealers hooked into water at the time. It was one of those screw connectors and once we got our hand into the water heater access (where the bypass valves were), we found the wet spot on the floor and right above it was a not tight enough connection. Just a little twist and all was well.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-14-2006, 03:31 AM   #8
JDL
JDL's Avatar
T , Oregon
Thank you all for the replies.
Took it the dealer. He could not find anything wrong. I had them replace the city water connection just in case.
Also bought a pressure regualtor at camping world with a gauge.
I suspect the water pressure at camp was just too high for the internal regulator.
JDL
Old 08-14-2006, 01:16 PM   #9
Kintscher's Avatar
Eugene , Oregon
We had a similar leak on our 2005 19' CCD. It turned out being the City Water Connection. Once it was replaced it hasn't leaked.
Kintscher is offline   Reply With Quote
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water leak Raptorrider2001 1997 - 1999 Safari 19 09-18-2005 08:21 PM
City water 53flyingcloud Fresh Water Systems 2 07-11-2002 12:08 AM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
