Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 05-24-2005, 08:46 PM   #1
rfield54's Avatar
Profile:  1980 28' International
1989 29' Excella
2002 19' Bambi
Avon , Colorado
Images: 105
Send a message via AIM to rfield54
Leak in belly, by city water inlet...HELP
After de-winterizing my '02 Bambi this week, I noticed after hooking up to city water, a fair amount of leakage through any openings in the belly pan, near the city water inlet. The leak is coming from between the flow valve located after the city water inlet, and where the pipe comes through the wall under the shower (heading curbside inside the storage area, below the storage door). I figure the problem is at or just beyond the water pressure regulator inlet flow valve thingy, because it also leaks when I switch to the water pump (though not as much). I'm guessing this is not an all too uncommon problem, though I couldn't find any threads dedicated to this scenario. I assume I have to remove the rivets and pull that corner section of bellypan, which is made of plastic. It looks like I have to remove the trim to get to the rivets on the top of the panel. Has anyone out here done this job? I'm new to rivetting. What size drill bit and rivets? Any suggestions out there? I know, I know...I'm buying an air compressor this week. Thanks, Roy
AIR #2753
www.roybloomfield.com
rfield54 is offline   Reply With Quote
Old 06-02-2005, 07:31 AM   #2
rfield54's Avatar
1989 29' Excella
2002 19' Bambi
Avon , Colorado
Images: 105
Well, no replies last time so I'll run it up the flagpole one more time.
AIR #2753
Old 06-02-2005, 09:25 AM   #3
somefun's Avatar
Profile:  1974 27' Overlander
Puyallup , Washington
I usually use a 1/4'' bit to drill the heads off the rivets. Then you can remove the piece that's riveted in place and many times the remainder of the rivet will just fall off; kind of like taking the head off of a screw or nail. If necessary, use the proper size bit to drill the remainder out. (you can visually match the size -- I think it's usually 1/8"?). Rivets and rivet guns are readily available at most hardware stores.
Hope this helps!
Curt
somefun is offline   Reply With Quote
Old 06-02-2005, 12:02 PM   #4
BoiseState
Spiffy Gem's Avatar
Profile:  1966 22' Safari
All my life in , Idaho
Images: 41
I don't know your year/model, so my comments may not be of value to you.
I am working a '66 Safari. The city water inlet of my unit had a rubber seal in it, much like a garden hose. If your system is like this, I would start there. On my Gem you can completely remove the water connection device without involving the floor or belly skin.
If water was not drained from this prior to winter, it is possible freezing has cracked the metal housing.
Spiffy Gem is offline   Reply With Quote
Old 06-02-2005, 12:07 PM   #5
BoiseState
Spiffy Gem's Avatar
Images: 41
One other thing . . . if the city water inlet section of your water system was not included in your winterizing routine , you may have to replace that section of line . . .
Old 06-02-2005, 03:24 PM   #6
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Well, you can see the city water connection inside plumbing and associated areas from behind the rear vanity. Open up the doors, clear the shelves and take a peek. Place you hand in the opening, down the interior wall as far as your hand/arm can go and see if you can feel where the issue is...maybe even see it.
Old 06-02-2005, 06:12 PM   #7
AirConditioner's Avatar
Profile:
I suspect you had water remaining in the pipe assembly connecting to the pressure regulator. If you had freezing weather this could easily have done the damage. This weekend when I pressurized my system I experienced a similar failure in my feed line to my toilet. Seems that the flexible line from a copper water pipe to the toilet had water remaining after I winterized. Even though I blew out the pipes with air for over 30 minutes, I could not clear the water from this low point. After you fix your problem you might wish to examine the piping for any low points that do not drain well and correct these.
AirConditioner is offline   Reply With Quote
Old 06-02-2005, 11:51 PM   #8
rfield54's Avatar
1989 29' Excella
2002 19' Bambi
Avon , Colorado
Images: 105
Thanks for the replies. I'll take a closer look tomorrow. - Roy
AIR #2753
Old 06-03-2005, 12:06 AM   #9
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
Looks like a good thread to bring up this water leak finding method.
Instead of pressurizing the system with water, make an adaptor to your air compressor. Just hook the air right to the city water inlet.
This will allow you to locate the leak without getting the floor all wet. It also helps in finding the leak by listening to the lines or useing soapy water from a brush.
If you don't have a compressor it gives you a good excuse to get one for your winter blowout.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 06-03-2005, 06:19 AM   #10
Aluminut
I rarely use the city water connection, but maybe once or twice a season, and ususally near the beginning or middle of the season (so far). It's a great point to blow out the lines. Looking at my city water connection from the inside, it looks to me once it pokes in, it goes straight down and perhaps when I winterized in the past with just plain antifreeze, I was just lucky.
Old 06-03-2005, 10:27 AM   #11
rfield54's Avatar
1989 29' Excella
2002 19' Bambi
Avon , Colorado
Images: 105
I had read on another post that an effective way to winterize the section just after the city water inlet (after blowing out the lines) is to put antifreeze in a (short) hose and, with the compressor, blow it into the city water inlet. Probably best to do this before bringing antifreeze into the system via the water pump, so as not to blow out all the antifreeze.
PS: I just bought a Porter-Cable compressor yesterday (it's about time).
AIR #2753
Old 06-06-2009, 01:27 PM   #12
Profile:  1990 29' Excella
Gainesville , Florida
Airstream Registry
I just dug this thread up because I seem to have the same problem on my 1990 Excella when I hook to city water. I can follow the pipes in and can find no leaking inside nor do I have a wet floor anywhere. Just drips out of belly pan below the inlet, but where inlet goes thru the skin, it is perfectly dry. How was this one fixed?
Joe
AirHeadsRus is offline   Reply With Quote
Old 06-06-2009, 01:44 PM   #13
Crusty's Avatar
Profile:  1992 34' Excella
On my 92 Excella, my city water inlet started leaking and I found that because of the way that it is made (two pieces - one installs from the outside and the other one from the inside with the actual parting plane winding up in between the inner and outer skins) that the water was leaking inside my walls, draining through the insulation down to the bottom where it thoroughly soaked the floor without me able to even see it because of the carpet and protective plastic overlay in the storage compartment. It ruined my OSB floor in that area before I even noticed it dripping outside.
Crusty
"If you come to a fork in the road, take it."
Austin, TX "Rancho Deluxe"
Crusty is online now   Reply With Quote
Old 06-06-2009, 03:21 PM   #14
Airstream Registry
Crusty, you are exactly right. I looked a little closer where it was coming thru the wall and there was a drip coming in. It was flooding between the walls and that is why I had water coming out all over the belly pan where it could find an exit. I don't think there is any damage because I caught it early. How did you replace and did you use another part like the one that went bad. Mine looks like there are 4 screws on the outside and 4 on the inside.
Once I get that fixed, I'll have to find out why my pump is running and no water is coming out. I had water when I filled up the fresh the first time, but now I don't.
Any ideas would be appreciated.
Thanks, for your reply.
Joe
Water leak Raptorrider2001 1999 Safari 19 09-18-2005 08:21 PM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 08:28 AM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 12:48 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
City water 53flyingcloud Fresh Water Systems 2 07-11-2002 12:08 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
