05-11-2010, 08:19 PM
#21
Boerne
yup, Mine's the same too and leaks at the seam between the two halves. I tried some silicone as a gasket but it didn't work. The floor in my '34 is gone in the rear corner so I have a project there to remove the bed and replace the flooring. There is a source I found while searching for a new piece. It is a combination check valve and pressure regulator just like the AS manual says it is and you can buy it in chrome.
SHURFLO CITY WATER ENTRY - RVWholesalers.com RV Parts
James B
05-13-2010, 08:51 PM
#22
2022 25' International
Savage
Pictures of the leaking part and Water Damage
Here are the pictures of what I found. In the shot of the water inlet, everything looks fine from the outside. Inside you can see the water damage. I believe I caught it soon enough, before the floor was damaged and too far gone. Note the trail of where the water was flowing out from the wall (The OSB looks clean). I sprayed bleech water (50/50 solution) to stop the mildew. You can also see the DampRid drying kit I am using to draw out as much moisture as possible. The last pictures shows where it was leaking through the belly pan, and on to the frame. I have already ordered the new part as provided by texascanuk (thank you!)
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
05-13-2010, 09:25 PM
#23
Trabuco Canyon
I had the same issue with mine when new. My city water fitting would only leak when the water heater would cycle. It would also drip out of the pressure relief valve at the same time.
It was difficult to track down because it dripped under the shower and since I used the water heater before showering, I suspected the shower leaking. But I kept looking around and finally caught the city inlet dripping. On my trailer it is easy to reach around and feel all the city water inlet fixture, because they cut the hole much too large
In my case an expansion tank cured the city water inlet leak, and the water heater relief valve drip.
05-16-2010, 06:16 AM
#24
Boerne
TS8501,
next to the pail of damp rid there is a valve in the water line, where does that go? What's it for?
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley. 1600 Watts Solar/ 400Ah Lithium batteries
Tow With: 2006 Dodge 2500 Quad LB 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr, Bilstein Shocks, Ingalls balljoints.
05-31-2010, 02:40 PM
#25
Boerne
Originally Posted by texascanuk
TS8501,
...OK, i got it. It's a valve that drains the water, probably needs to be pumped out through it, or used to drain system prior to storage for winter. I found the water tank drain at the street side behind the center wheel. What a strange place to put it, certainly not convenient.
Here's a picture of my floor damage. You can see what a mess a neglected leak can cause! P.S. it wasn't me..
[IMG]file:///C:/DOCUME%7E1/Barry%27s/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]I intend to cut the floor back to the crossmember near the rolled up carpet and
James B.
05-31-2010, 04:22 PM
#26
2007 25' Classic
Port Angeles
James... darn that's a shame... you poor guy.
I bought our first Airstream on April Fools Day. Photo's like this are what nightmares are made of, at least for me. Good luck.
05-31-2010, 06:20 PM
#27
Central
, Mississippi
...I intend to cut the floor back to the crossmember near the rolled up carpet and
ARRRGGGG---Flashbacks.... http://www.airforums.com/forums/f36/...r-54952-5.html
If I can offer a suggestion, do the splice between the crossmembers with a large backing piece and lots of glue. I HAD to make one slice on a crossmember and there is a noticeable peak at the joint.
Good luck...
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Water leak
Raptorrider2001 |
1997 - 1999 Safari |
19 |
09-18-2005 08:21 PM |
Water Leak
jcanavera |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
9 |
06-03-2005 08:28 AM |
Cracked City Water Connector
wagsrp |
Fresh Water Systems |
0 |
08-09-2002 12:48 PM |
city water inlet valve failure?
JohnGalt48 |
2 |
08-01-2002 04:43 PM |
City water
53flyingcloud |
2 |
07-11-2002 12:08 AM |
