Old 02-24-2015, 09:30 AM   #1
2005 34' Classic S/O
Juneau , Alaska
Exclamation LEAK: Fresh Water Fill
Help! We have a leak (stream) coming from the screen which is right next to the Fresh Water Fill tank (passenger side with lock on it). We have never used the tank. So why is there a steady leak.
Help! I called Airstream and they suggested a possible faulty water pump?
What do you ALL think?
Martin & Judith Lentz
Darbie and Jessie (our dogs)
2004 King Ranch F-350
Classic LTD 2005 34 with slide
You may plan your journeys but God is incharge of your steps
judithd is offline   Reply With Quote
Old 02-24-2015, 10:25 AM   #2
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Not trying to be a smart @&$......but is the tank full?
Landrum is offline   Reply With Quote
Old 02-24-2015, 10:33 AM   #3
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Water pump for sure. Bad check valve allowing water to flow backwards into the fresh water tank. Have had that happen on 2 new trailers.
Al - K4GLU is offline   Reply With Quote
Old 02-24-2015, 10:41 AM   #4
jackson center , Ohio
Are you hooked to city water? If so unhook and see if water stops coming out of the vent. If it does it is the check valve
Schu is offline   Reply With Quote
Old 02-24-2015, 10:58 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If water is leaking out the fill port, then the tank is definitely full now!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-24-2015, 12:24 PM   #6
Juneau , Alaska
Actually, I have not had the water pump running since I have been hooked up to city water. So, I ran it when I took shower and it stopped leaking. So for now, Thank You all for your responses. If it starts leaking again. I will test your suggestions.
DON'T DRIVE FASTER THAN YOUR ANGEL CAN FLY
Old 02-24-2015, 12:41 PM   #7
The reason it stopped leaking is because you used some of the water in the tank and it's no longer full. As soon as it fills again the leak will be back. If the check valve fails you don't have to run the pump for water to flow back through it to the fresh water tank when you're hooked up to city water.
Old 02-25-2015, 10:58 AM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I wish my gas tank would do that!!!
Old 02-25-2015, 11:14 AM   #9
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Definitely a faulty check valve that's stuck open. Happened to me. The city water pressure is filling your fw tank and it is overflowing through the overflow tube next to your fw tank cap.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 02-25-2015, 12:05 PM   #10
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Amen to check valve problem.
I have had the freshwater tank out of mine and replaced it. I am more familiar with freshwater tanks than I ever wanted to be.
You are getting water bypassing back into the tank when you hook up to city water. It overfills the tank and it comes out the tanks overfill/vent which is port with the screen over it inside the potable water access door.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-25-2015, 01:27 PM   #11
KYAirstream's Avatar
Northeastern , Kentucky
Any concerns if left this way so the tank could be filled in the future via the city line? Maybe an additional shutoff valve for times when hooked to city water to prevent fresh tank fill up.
KYAirstream is offline   Reply With Quote
Old 02-25-2015, 01:36 PM   #12
acstokes's Avatar
2009 30' Classic
I added a ball valve between my freshwater tank and water pump just to keep it from happening again. It means if/when I want to use my fw tank I just need to open the ball valve.
Fred Stokes
WBCCI #2810
Noobie - how to fill fresh water tank? Bohemian Fresh Water Systems 26 10-18-2016 01:51 PM
Unable to Fill Fresh Water Tank forthefew Fresh Water Systems 3 09-06-2010 07:16 PM
Fresh Water fill from City Inlet question Distantdrummer Fresh Water Systems 7 07-15-2010 05:38 PM
Fresh water tank fill jfowler218 Fresh Water Systems 4 04-21-2009 07:36 PM
Fresh water fill Safari Tim Fresh Water Systems 6 05-20-2007 03:50 PM
