Old 05-15-2016, 12:30 PM   #15
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Brian - is there any risk of cross contamination with your hose for the black flush and drinking water sharing a y-splitter? I'm assuming there isn't or you wouldn't have set it up that way - but I don't know how it all stays safe.
SteveSueMac is online now   Reply With Quote
Old 05-15-2016, 01:35 PM   #16
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Hi Steve. There is a backfkow preventer valve on the Sewer Solution unit. Not to say that it can't fail, but it hasn't yet on any of the three Sewer Solutions that I have had over the years. On my original Sewer Solution, I replaced the plastic backfkow valve that came with the Sewer Solution with a brass one that I bought at a ranch supply store. I believe that I still have it and should probably install it at the Y splitter.
In all of our many nights of Airstream camping, the Sewer Solution has never given us a problem. In our early days when we used a slinky, we had many issues including pin holes that were seeping raw sewage on the campsite, and cleaning the slinky after a black tank dump was always a fun job.
Brian
SuEllyn & Brian McCabe
Old 05-16-2016, 07:30 AM   #17
2016 28' Pendleton
East central , Illinois
Thank moosetags
We just purchased a 2016 airstream Pendleton. Trying to see what we will need to be on the road. We are moving from a much smaller camper. Your advice is greatly appreciated.
Gina
GinaNBob is offline   Reply With Quote
Old 05-16-2016, 07:44 AM   #18
W , New England
Thanks for the info, Brian!
Old 05-16-2016, 08:05 AM   #19
2015 23' Flying Cloud
Livermore , California
Kwiklink Connector for City Water
How hard is it to remove the city water outside plate on a FC 23D?
cactusjk is offline   Reply With Quote
Old 05-16-2016, 08:18 AM   #20
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by moosetags View Post
I use brass quick connects at every hose connection. I buy these at Tractor Supply Company. They have the best price on these. Buy only the solid brass quick connects. The aluminum ones are junk.
At the time I bought mine I had never even heard of Tractor Supply Company. The brass ones I bought at Home Depot corroded and I got rid of them. Brass is made of copper and zinc, and the spring-loaded ball bearings that hold the male and female ends together are steel, so when the quick disconnects got wet, galvanic action between the zinc and steel caused the zinc in the brass to oxidize. So the brass quick-connects at Home Depot are junk, too. Maybe the ones you bought at TSC are all-brass, no steel parts, so you don't have that problem.
I finally went with plastic quick-connects that work just fine as long as I avoid using them in below-freezing conditions where they would become too brittle. But since I don't use a municipal water hookup in below-freezing temperatures anyway, that's a moot point.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-16-2016, 10:05 AM   #21
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Brian, do you find the water pressure/flow sufficient with the 3/8 hoses?
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 05-16-2016, 10:44 AM   #22
moosetags's Avatar
The brass plumbing quick connects that I have been using do have steel ball bearings in the female end. Some of the ones I am using are about ten years old, and I have not experienced any rusting. On the other hand, the aluminum connects that I bought quickly developed corrosion and were useless.
Brian
Old 05-16-2016, 10:52 AM   #23
moosetags's Avatar
Hi Michael. The Blue curly hose in the picture is a 1/2 inch. The purple hose to the Sewer Solution is a 3/8 inch. I used to use a 3/8 inch for the city water supply, and "upgraded" to a 1/2" when I last replaced it. I noticed absolutely no difference in the water pressure or flow inside the trailer. I am guessing that between the pressure reducer that I use at the city water source and the one installed in the Airstream, I am not getting any increased water flow from the 1/2" hose.
Brian
Old 05-16-2016, 10:57 AM   #24
moosetags's Avatar
Disregard that last picture. It is one that was taken before I went to the 1/2" hose. Here is the correct photo with the 1/2" hose. Sorry about that.
Brian
Old 05-16-2016, 12:15 PM   #25
AWCHIEF's Avatar
Images: 33
Brian, thanks I have been needing a couple of new hoses. Going to give the curly ones a try.
MICHAEL
Old 05-16-2016, 02:08 PM   #26
Can someone point me to a good discussion on ext water filters? Not sure I need the double cartridge approach.
Old 05-16-2016, 02:14 PM   #27
AWCHIEF's Avatar
Images: 33
Google "Airforums water filters". Several good hits.
MICHAEL
Old 05-19-2016, 05:51 AM   #28
Can the city water connection faceplate be easily removed from the outside?
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 10:25 PM
Water hose connector / Outside Airstream Devoman Plumbing - Systems & Fixtures 17 01-26-2010 05:27 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 08:09 PM
broken water hose connector ylander Plumbing - Systems & Fixtures 0 06-09-2004 05:27 PM
Cracked City Water Connector wagsrp Fresh Water Systems 0 08-09-2002 01:48 PM
