Old 07-24-2008, 12:18 PM   #1
Lake Lure , North Carolina
Kitchen Sink Hot Water
I have a 1974 31 ft. International with a center bath. My hot water heater works and I get strong hot water flow in my bathroom sink and shower. I only get a trickle of hotwater flow to my kitchen sink. I don't know if the lines are all tied together or if the kitchen sink has a seperate line from the hotwater tank? What should I check and where do I start. Thanks, Wally Gilbert
wlgilbert40 is offline   Reply With Quote
Old 07-24-2008, 02:11 PM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Remove the aireator (sp) or screen from the kitchen faucet. Is the cold water flowing? There could be an obstruction of calcium, sand, (crud) in the line. Hope this will help.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 07-24-2008, 02:15 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Ours had strong water pressure to all other faucets except the kitchen faucet. I removed the aerator and found all kinds of nasty gunk there, lime deposits, dirt, grunge, even bugs.
Old 07-24-2008, 03:31 PM   #4
Naperville , Illinois
slow faucet
Also, take the handle off of the hot water side and remove the stem from the faucet, I'll be the rubber gasket is all chewed up and blocking the flow. While your at it, it would pay to change BOTH gaskets.
nodpete is offline   Reply With Quote
Old 07-24-2008, 08:51 PM   #5
Mexray's Avatar
1978 28' Ambassador
Morada , California
We have the same problem...the galley faucet is a single Moen unit...cold flows great, hot hardly at all...replaced the Moen faucet cartridge...no change.
I've looked underneath and have noticed that the copper tubing from the rear is 'necked down' to a smaller size where it's hooked to the Moen inlet pipes.
I'm thinking that there is some 'crud' in the area of the hot water tubing where it's necked down in size.
I guess I've got to figure out how the try and 'blow' the hot line with some air pressure - backwards - to see if I can fix it....problem is that all the lines are soldered copper tubing from the back...no hose to take off...perhaps I'll have to cut the copper tubing, blow it out, and then repair it with a hose connector and some hose clamps...AND blowing through the Moen single faucet has it's own problems...
If I knew the obstruction was definitely in the necked down area, I could just cut that area out and replace with a hose tubing 'repair'...
Has anyone tackled this problem? Any info would be helpful.
Ray & Pat; Morada, CA
Old 05-02-2009, 05:43 PM   #6
msieber109's Avatar
1966 24' Tradewind
1975 29' Ambassador
Greenfield , Massachusetts
I have just the opposite problem.... I have no cold water at my kitchen sink in my Ambassador. I have been searching the forums with no answers as of yet. I have cold water all the way up to and into the water filter chamber. I have a single handle kitchen faucet and the hot water flows great.
The filter chamber was full of anti-freeze and no filter. I cleaned it out and put it back on with no filter cartridge. The chamber filled with fresh water but nothing up to the sink.
Does there have to be a filter in the chamber for the water to flow?
msieber109 is offline   Reply With Quote
Old 05-04-2009, 10:05 AM   #7
What I finally did was to open the hot water tank valve, disconnected the facet from the hot water line, took my small compressor and applied air at the facet line side( backflow). The blockage was removed and the hot water pressure was again fine. The same could be done for the cold water side but proceed with caution as you don't want to rupture a plastic tank or crack a plastic fitting.
wallygilbert is offline   Reply With Quote
Shower grey water reflux from kitchen sink jordandvm 2002 - 2005 International 12 12-17-2011 02:10 PM
Refinishing the kitchen sink 48-remi Sinks, Showers & Toilets 13 05-09-2008 09:06 PM
need new kitchen sink shantz Sinks, Showers & Toilets 4 03-24-2008 08:48 PM
not enough hot water from kitchen sink faucet codybear Fresh Water Systems 3 01-24-2006 10:20 PM
Kitchen sink lites FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 10:17 PM
