Old 02-04-2008, 05:18 PM   #1
1983 30' Airstream 300
Plantersville , Texas
Kitchen Faucet Repair
My kitchen faucet has started to leak. I got the handle off and I got the
c-clip off . now I can't get anything to unscrew so I can get the cartridge out to check if I can repair with new o rings or a new cartridge. There is 2 white plastic ears and a split brass circle. It is a Moen single handle kitchen faucet without a sprayer. I would post a picture but my camera won't download to my computer. Any help will be appreciated.
If I can't get the cartridge out I will just replace the whole faucet . I would rather fix this one.
Kay
carnegie1935 is offline   Reply With Quote
Old 02-04-2008, 05:30 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Kay -- This is harder to answer because your profile doesn't list what Airstream model this might be. You can go into your control panel (User CP) toward the upper left of any Forums page; select 'Edit Profile,' scroll down to 'Additional Information,' make a choice under Trailer #1, scroll down and click 'Save Changes' at the bottom of the page.
5 meter Langford Nahanni
Old 02-04-2008, 05:31 PM   #3
bertro's Avatar
1971 23' Safari
Groveport , Ohio
I dont know what year your working with not that I could help anyhow if I did, But forum member Ganglin has rebuilt some. Mabey he will chime in. Robert
bertro is offline   Reply With Quote
Old 02-04-2008, 05:53 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Kay,
Does this look like what's sticking out of what you have left. A brass U clip goes across it?
Old 02-04-2008, 05:57 PM   #5
more infomation
I was tired when I posted the request and I left out needed info. Sorry about that.
It is in my 83 300 turbo deisel motorhome. The model of the faucet is M7600
there is another number that I don't think is important . it is 4103709. I don't have the pamplet that should be with the rv papers.
Thanks, Kay
Old 02-04-2008, 06:00 PM   #6
Thanks Ganglin
Yes it looks like that except it has white plastic ears between the outside brass ears
kay
Old 02-04-2008, 06:02 PM   #7
Excella CM's Avatar
1978 31' Excella 500
Venice , California
The retainer hairclip style clip pulls out the side, then the center control barrel pulls straight up and out.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 02-04-2008, 07:09 PM   #8
2004 25' Safari
1971 27' Overlander
Jourdanton , Texas
If it is a moen
If you don't get a direct answer here, Moen has a lot of instruction literature online. They also have a decent telephone help line.
pienjim is offline   Reply With Quote
Old 02-04-2008, 07:28 PM   #9
2004 25' Safari
1971 27' Overlander
Jourdanton , Texas
I missed a source
Since the Texas State Vintage rally is just the road in Montgomery this weekend, there should be someone in the crowd with the answer. If you aren't signed up for the rally, at least come to the public open house on Saturday afternoon.
Old 04-05-2008, 10:11 AM   #10
1999 25' Safari
Carlsbad , California
New Faucet?
I have a faucet like Carnegie, but a plactic piece is broken and I can't fix it. Does anyone know where I can purchase a new facuet? I didn't find one on the Moen web site.
Jfuller678 is offline   Reply With Quote
Old 04-05-2008, 10:59 AM   #11
1976 25' Caravanner
Campton , New Hampshire
Not sure what plastic piece you're refuring to , if it is on the cartridge you can replace the whole cartridge . Most well stocked hardware stores have them , if not a plumbing supply. Replacing the cartridge make a big difference in the ease of operation.
ticki2 is offline   Reply With Quote
Old 04-05-2008, 05:38 PM   #12
Thumbs up replacement faucet
Please forgive me for not updating this thread with my fix. I finally gave up on getting the cartrage out and I went to lowes and bought a new kitchen faucet with a single handle. It is also a moen ,but any brand would be ok. I wanted to replace the filtered water dispenser so I got a faucet with a spray hose to fill that hole. Lowes had some moen cartrages,but not the one for my faucet. when I removed the nut that held the faucet to the counter top the cartrage almost fell out. I had to drill an additional hole or at least make the original hole larger as the hot and cold inlets were farther apart. After all the frustration in trying to remove that cartrage and then not being able to find the right new one, I had a good stress releaving laugh when the cartrage came loose.
It took less than an hour to replace the faucet and spray hose. I have no leaks and life is good again. It looks pretty close to the original.
Kay
Old 04-05-2008, 05:58 PM   #13
1973 25' Tradewind
Romulus , New York
Upgrade
I have found that replacing the whole fixture is easier and cheaper ( what is YOUR time worth?) It is nice to know that you have fixed that dang thing forever!
jayray5 is offline   Reply With Quote
Old 01-17-2009, 05:53 PM   #14
Punta Gorda , Florida
Moen model M7600 kitchen faucet
I too have this same model that must be 18 years old or more. Moen does not recognize the model. If you have any success with your unit let me know where you got the info.
Rich (rich1)
rich1 is offline   Reply With Quote
Replacing kitchen faucet Sovereign86 Sinks, Showers & Toilets 5 09-13-2007 06:57 PM
Kitchen Faucet Repair hhessig Sinks, Showers & Toilets 2 05-23-2006 03:16 PM
Installed new kitchen faucet! Stefrobrts Fresh Water Systems 18 07-16-2004 11:33 PM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 05:02 PM
